Old 09-09-2012, 10:46 AM
Bill Denton Bill Denton is offline
Default Eleven Rack Output Question
I did a search here and did a quick "skim" of the manual, but could not find this information...
With the Eleven Rack, is it possible to get one pair of outputs with the 11R effects, and another pair of outputs that is "clean", with no effects applied?
Can you have one of these signals feed the analog outs, with the other signal feeding the digital outputs?
Thanks...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 09-09-2012, 11:06 AM
Default Re: Eleven Rack Output Question
Thanks...
Bill
You can position the FX Loop block or the amp1/2 outputs in different locations in the Eleven Rack internal rig chain, including right at the front of the chain. Amp1 and amp2 outputs can be at different locations or the same (e.g. if for a stereo pair if downstream of a stereo FX block)
The Amp 1 (front panel) / Amp 2 (rear panel) outputs are more "instrument level" than line level outputs.
The FX Loop ins/outs can be switched (back panel button) for -4dbu/-10dBV line level. Its a parallel FX loop with a wet/dry mix control, so splitting off the FX outs and using them for whatever you want does not disrupt the main rig signal. You can adjust the FX Send output level with the FX Loop block. Without knowing exactly what you plan in feeding its not possible to say if you'll get the exact level you will want.
BTW you can also get the guitar input out the digital connectors using the "split in/out" setting.
Obviously if you are tracking with the Pro Tools as an interface you also direct access to the guitar input signal in Pro Tools, or other DAWs.
Darryl
Eleven Rack Output to Amp buzz antonis Eleven Rack 45 10-31-2017 06:59 AM
Eleven Rack output in live situation, Bug or what? darren051234 Eleven Rack 10 06-20-2013 04:47 AM
Eleven Rack Output to Amp dress4riot Eleven Rack 1 03-26-2013 10:59 AM
Eleven Rack no output HELP US! Markownage Pro Tools Software (Win) 3 08-04-2012 06:47 PM
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs MR290378 Eleven Rack 12 11-29-2011 05:10 PM
