#21
Re: Mac OSX 10.8 - Mountain Lion on Pro Tools LE 8
Jim |
#22
Re: Pro Tools LE 8 on Mac OSX 10.8 Mountain Lion?
I figured out the problem :)
I did try and install the drivers again, but the new Mountain Lion made me force eject it saying it was damaged....every time. I had a similar problem with Carbon Copy Cloner. When this happened with both i notice when installing CCC that there was an issue with my security settings? Never had that before......well.... After going into System Preferences>Security&Privacy, i see this... -Mac App Store -Mac App Store and identified developers -Anywhere once i clicked "anywhere", all programs installed perfectly including the drivers for the Mbox 2 Mini :) |
#23
Hi all,
I've just got Pro Tools LE 8.0.5 running successfully on Mountain Lion! I'm running a late 2008 Unibody Macbook Pro 2.66, but I did a clean install of Mountain Lion on a freshly formatted external 500GB USB Hard Drive to test compatibility with my apps before deciding if I would risk the full upgrade on the laptop. I installed Pro Tools LE 8.0 first which seemed successful, but Mountain Lion wasn't recognizing the PT hardware (currently an MBox2 Micro but I have an MBox2 as well) so I updated the MBox drivers (labelled drivers for Pro Tools 9) from the didgidesign website. http://avid.force.com/pkb/articles/e...nload/en379411 This kicked the MBox Micro into life, but Pro Tools LE 8 was quitting at the end of start up. I then updated to 8.0.5 and its working fine. I've got 5 tracks of audio running with compression, eq and fx. I haven't yet tried recording into pro tools with the Mbox2, but this it is working!!! I don't know if an upgrade on to of an existing version of OSX would yield the same results, but I'm very surprised and happy its working for me. I hope you guys all have the same success. I'm so happy I'm using emoticons. |
#24
Max - so to confirm then, Pro Tools LE 8.0.5 with your MBox2 Mini is now working on OSX 10.8 Mountain Lion? Have you recorded/edited at all to make sure it is working normally? What are the specs for your Mac?
Did you install the drivers from that link I sent you or...? Thanks! |
#25
Ok i installed Mountain Lion, and M-Powered 8.0.5 seems working fine for now...no complains.
Cheers |
#26
I only have the MBox 2 mini, so i personally cannot confirm that particular version of Pro Tools. Sorry The drivers from the site you suggested did work, only after fixing the security&privacy settings in system preferences. Thank you :) Last edited by maxspeedstudios; 07-26-2012 at 09:37 AM. Reason: Missed a response |
#27
Max - I understand you have the MBox Mini but aren't you running some version of Pro Tools with it?
Thanks! |
#28
I would like to try protools, but have yet to acquire it. |
#29
1) Mbox Mini 2 that works - but with a software other than protools 2) M-Powered 8.0.5 that seems to be working fine Anyone tried an Mbox 2 with Protools LE 8.0.5 yet? And if so - can you provide your system 'stats' as well. Thanks again |
#30
Which interface do you use? I use Fast Track Ultra with PT MP 8.0.5 too, will that work as well?
Pro tools 10 & mountain lion | Mr.J | Pro Tools 10 | 1 | 08-31-2013 04:01 AM |
Pro Tools LE 8.0.5.1 & Mountain Lion | plin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-30-2013 02:34 AM |
Impossible to start Pro Tools on MacPro after downgrade Mountain Lion back to LION | DESVED | Pro Tools HDX & HD Native Systems (Mac) | 2 | 05-21-2013 03:18 PM |
Pro Tools 8.0.5 Mountain Lion Mac 10.8 | madballa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-19-2013 07:10 PM |
Pro Tools 10.2.0 on OSX Mountain Lion | drot1 | macOS | 2 | 08-20-2012 09:51 AM |
