Old 05-09-2012, 12:10 PM
MediaBCD MediaBCD is offline
Default Windows optimization?!?
I was checking the new optimization for W7 and found that it was a lot shorter than the optimization for XP was. Should I also do the steps that are in the one for XP that can be done on win7?
Old 05-09-2012, 12:32 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Windows optimization?!?
Depends on how it runs....I think i did most of those XP steps on my WIN7 machine out of habit....and I didn't have any issues releated to those optimizations....however your milage may vary which would lead me to say......if it's running fine now....i wouldn't mess around with it.
Daniel
Old 05-09-2012, 12:44 PM
luciancazacu luciancazacu is offline
Hi MediaBCD! Follow this link and the other 8 created by avid for windows 7: http://www.youtube.com/watch?v=k86R-QQ1s40
Old 05-09-2012, 12:47 PM
Hi! Follow this link and the other 8 created by avid for windows 7: http://www.youtube.com/watch?v=k86R-QQ1s40
Old 05-11-2012, 07:20 AM
GearGuy GearGuy is offline
Great resources here as well.... I've been using Sweetwater's support optimization help for years:
http://www.sweetwater.com/sweetcare/...-optimization/
And specifically for Win 7:
http://www.sweetwater.com/sweetcare/...for-windows-7/
Old 05-11-2012, 07:23 AM
I've been using Sweetwater's optimization support for years.... they have always been a great resource, all the way back to the Windows XP days:
And specifically for Windows 7:
Old 05-11-2012, 01:30 PM
Shan's Avatar
Shan Shan is offline
I would NOT recommend and even promote some of these settings for Pro Tools you just posted. This is best optimization resource for PT and W7(and XP).
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 05-11-2012, 01:43 PM
There's only two different settings in the one of Sweetwaters and the one from Avid. Although I can not tell what impact those two would make.
Old 05-11-2012, 05:36 PM
Shan's Avatar
There's more than two, and the impact will be DAE errors. Why would one not follow Avid's optimizations and attempt something else is a head scratcher. There's also other advanced settings beyond what Avid has posted, but most of theirs not followed will result in known DAE errors. Pro Tools is a different beast. Following generic audio optimizations that are good for other DAW's is something I wouldn't recommend. The Sweetwater ones are an example of this and they need to update what they posted. Most of the classic Black Viper tweaks will only give gains in more available RAM when it comes to PT. A moot point now that we can run PT in W7 64 with more than 4G of RAM. If you have 8-24G of RAM and Windows takes up 2G, it doesnt really matter anymore. At least PT can use the full 4G that it can in that scenerio plus a ton more for disk cahce.
Shane
Old 05-11-2012, 08:27 PM
dave911's Avatar
dave911 dave911 is offline
I always stick with the Avid recommendations and only for my current OP version.
For W7 they want DEP on (W7 default) used to be Off for XP.
Windows Optimization mesaman Pro Tools M-Powered (Win) 1 12-27-2010 10:39 AM
Protools 8.0.4 not needing optimization to run on windows 7? BassChase Pro Tools M-Powered (Win) 1 07-10-2010 07:16 AM
windows 7 optimization simon lefisch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-06-2010 04:20 PM
Windows Optimization darkglass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-18-2004 07:17 AM
Windows XP optimization - AMIII card. The Electric Trombone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-10-2002 06:46 AM
