Old 04-30-2012, 10:17 PM
Wayne Rose Wayne Rose is offline
Default Sudden Voce Chorus-Vibrato Authorization Error in PT 9.0.6
I'm running Pro Tools 9.0.6 on Mac OS 9.6.8.
Everything has been running smoothly until suddenly, I received a "Fatal Error-unloadable executable" message, i.e., "no valid authorization could be found, the iLok key was not connected or the plug-in was damaged".
I checked my iLok account and the license appears to be in tact. My iLok key was connected. I tried replacing the plug-in with a safe copy I keep in another location, and when that did not work I downloaded and re-installed the Voce bundle for PT 9 from the Avid site. Still no go!
Oddly, Voce Spin, also part of the bundle, continues to load in PT with no error message, as do all of my other plug-ins.
The only hint I have is that Voce Chorus-Vibrato was working fine with exactly the same setup, until I downloaded and installed the latest Massey plug-ins demo package. I can't see how that should make a difference, but I removed the Massey Demos plug-in from the Plug-ins folder, just in case. Nothing doing!
This particular plug-in may not be critical to my daily routine, however, I purchased the license and would like to see it functioning the way it should - and has been until very recently.
I must be overlooking something.
Any helpful suggestions would be much appreciated.
Kind regards to all,
- Wayne
Old 04-30-2012, 10:26 PM
browniespeaks browniespeaks is offline
Default
Have you trashed prefs yet?
Sent from my SGH-T769 using Tapatalk 2
Clifford Brown III
Brown Audio Solutions & Services
www.brownaudio.com
Old 05-01-2012, 10:06 AM
Default Re: Sudden Voce Chorus-Vibrato Authorization Error in PT 9.0.6
Yes, Clifford. I did trash DAE and Pro Tools prefs as part of the process described above. Sorry, forgot to mention.
Thanks for responding. Any other thoughts?
-Wayne
Old 05-02-2012, 09:13 AM
Default
You prob tried to r install it already too.wondering what exe. Is damagef
Clifford Brown III
www.brownaudio.com
Old 05-02-2012, 11:51 AM
Hi Clifford,
Thanks for following up.
Sorry though, I don't understand. Tried to reinstall what exactly? What do you think might be damaged?
Kind regards,
-Wayne
Old 05-14-2012, 10:15 PM
*bump*
Noticed someone else in the parent thread is having issues with plug-ins suddenly requiring re-authorization.
Any deeper solutions, or at least thoughts about the issue, out there? Anyone?
Please and thanks ...
-Wayne
Old 05-26-2012, 05:06 AM
*bump*
I had some problems with several other plug-ins, related to a bug in Novation Automap 4.3 (which has now been fixed, by the way, and can be downloaded here: Automap 4.4.1).
To get all of the necessary plug-ins back, I eventually re-installed PT 9.0.1, then re-updated to PT 9.0.6. That did the trick!
Interestingly, Voce Chorus-Vibrato, which was not one of the plug-ins I had replaced now works as well!
Pro Tools must have somehow got corrupted. Go figure!
Hope this helps others experiencing similar problems.
Cheers,
-Wayne
"BF Voce Bundle v4" vs "Voce Chorus/Vibrato" Marcel Risberg AAX Plug-ins 2 10-24-2013 12:10 AM
Voce Chorus/Vib iLok auth stopped working JozMaz Pro Tools TDM Systems (Mac) 3 05-02-2012 12:02 PM
Chorus vibrato problem warmothjoe Eleven Rack 6 10-24-2010 03:42 PM
bombfactory chorus/vibrato tamasdragon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-04-2008 11:33 AM
DAE 9019 Error (All of a sudden) misssixty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-12-2008 11:01 AM
