Old 04-30-2012, 05:54 PM
yellow yellow is offline
Default 11r eleven rack window gone disappeared missing vanished POOF! (and no midi input)
hey everyone
My 11r gui window is gone, disappeared, missing.
its not in the pulldown menu, tho i see pt loading the plugin during startup.
i tried all the troubleshooting from here, avid, and anything i could think of including deleting all preferences, an uninstall,reinstall/clean install and using all default setups and its still gone.
also, midi does cannot be inputted. pro tools doesnt detect any input from my midi keyboard/controller.
funny thing is:
i tried it on another computer and the 11r gui shows up and the midi input works (on instrument/midi tracks).
what can i do to get my 11r window to show up because editing rig setup via hardware is not gonna happen. also, id like midi to work as well. its not the 11r, usb cable, midi cable, or hardware, its something with the software
running: 11r w/ EXRP, pt le 8.0.5, windows 7, 3gb ram, amd dual processor, etc....
thanks
Old 04-30-2012, 07:45 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: 11r eleven rack window gone disappeared missing vanished POOF! (and no midi input
Did you re-install the first section of the ERXP?
Maybe try completely deleting everything PT related, then re-install PT8.x then update to 8.0.5, then install the first section of the ERXP.
http://elevenrackusers.blogspot.com/...howing-in.html
Brian
Windows 10 Pro 64 Bit
Pro Tools 2018 | Eleven Rack + ERXP
Youtube Channel - BenoniStudio
Free Eleven Rack Tutorials, Rigs, and more
@BenoniStudio
Instagram
Old 04-30-2012, 08:32 PM
hi benoni
thanks for the reply. i thought i got ridda everything pt related by selected the third unintall options (uninstall pt and delete preferences, drivers, etc...). and like i said, then i did a fresh reinstall/clean install w/e its called, and then updated to 8.05 and then finally updated the ERXP plugins with the dpm/rsr files. the odd thing is the keyboard does not create any midi response either, yet on the other computer, the 11r window and midi work fine. so something with my laptop is not fully operating. should i delete everything again and try again?
thanks for ur help benoni, ur very generous with your time and knowledge and i appreciate it
Old 04-30-2012, 09:26 PM
Benoni's Avatar
So you have already checked the Midi input filter..... hmmm
Did you setup your keyboard in PT?
If you don't know how, just open the PT .pdf and search for MIDI
What kind of keyboard? Is it connected via USB or into the MIDI ports on the 11R?
It may be worth another total re-install.
Update Windows 7 to SP1 if you have not already.
Also make sure you launch Pro Tools with Run As Admin
http://protoolsquicktips.blogspot.co...using-pro.html
Brian
@BenoniStudio
Instagram
Old 05-01-2012, 05:46 AM
Hey
The keyboard is a korg pa500ort and its going into the 11r midi in. I *tried* setting up the Keyboard but it didnt work somewhere along the line, so either i did it wrong or my guess is its just not working on this laptop because like i said, on the other computer (which is running XP) WITHOUT setting up the keyboard in midi studio, the midi came in immediately as well as the 11r gui being there with the ERXP updated amps,etc.....also i do have windows 7 sp1 already installed.
i guess ill try to delete everything! im just not reformatting my HD for this cuz i cant afford to do that. Only problem is the windows xp pro tools only has a 2ghz single core processor and 1gb of ram, although im ordering 2gb of ram today because of this. i just liked the ability to be able to move the laptop, if anything else comes to mind, please post,
thanks
Old 05-01-2012, 07:28 AM
tried another install but i deleted and uninstalled everything i could find digidesign/avid related and still no 11r gui. no 11r in pull down drop menu "window", and no rig layout on startup. doesnt make any sense...
also redeleted any and all preferences and databases. messed with the hardware and midi i/o, midi studio, input devices, nothing. everything is said to 11r, from MTC reader and generator to midi devices
on another note, there is an "external" input device in the setup>midi>input devices menu, and i have no idea what that is...maybe thast the problem?
Old 05-02-2012, 04:58 AM
any ideas? i cant think of anything to fix this?
Old 05-03-2012, 05:05 PM
Benoni's Avatar
Have you read through the manual yet? Open the pdf that is installed with Pro Tools and give it a good read through.
I can't think of anything else right now, I'd need to see the PC in person.
Brian
@BenoniStudio
Instagram
Old 05-04-2012, 08:35 AM
yes i did read it. the 11r rig gui window simply isnt there and the midi doesnt work either, so some midi settings in the software must have changed, and resetting the prefs to default, uninstall/reinstalling didnt work. sounds like a format or at least a seperate partition for pt now, thanks
Old 05-04-2012, 03:35 PM
ok i made a new partition and tried again, common files went to the master c: drive of course, which might be the issue, no results
maybe thats that
10.3.6 = No Eleven Rack Window? brianiac5150 Eleven Rack 23 08-21-2013 02:59 PM
Eleven Rack - Can MIDI CC be used to select rig input adamqlw Eleven Rack 28 04-14-2013 09:15 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
Upgraded to PT 9, Eleven Rack Expansion pack disappeared! AndersDM Pro Tools Software (Mac) 5 06-17-2011 12:36 PM
