Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 10 Discussion
Old 04-14-2012, 01:09 PM
softvoices softvoices is offline
Default How to lowering my disc buffer (DAE Buffer)?
Hi people!
Iam new in protools.
I have installed Protools 10 Full version but when i run it, present this mensagens: "could not allocate memory for the disc cache. Try lowering your disc buffer (DAE Buffer), disc cache size, or engine voice count. if you got this error on lounch, delete your prefs and try again."
How can solve it?
Please help me!
Old 04-16-2012, 04:58 AM
max howarth max howarth is offline
Default Re: How to lowering my disc buffer (DAE Buffer)?
last time i looked it was under the setup menu:
setup>playback engine>h/w buffer size
best wishes
max
www.redfacilities.com
2 x 3.3 6core mac pro | 12gb ram | mac os 10.7.3 | nu5.5 | rme multiset/audiolink96 | 3 x 19" flat panels | decklink xt | waves8 | altiverb7
Old 04-16-2012, 02:31 PM
Originally Posted by softvoices View Post
"if you got this error on launch, delete your prefs and try again."
The answer is in the message.
http://lmgtfy.com/?q=how+to+delete+prefs+in+pro+tools
Scott Gatteño
Yessian
Old 04-25-2012, 01:39 PM
Default Fast track Ultra 8R
For my home studio I bought an Acer computer with an Intel Core 2 Quad, 2.66 GHz, 8GB RAM, Windows 7 Professional 64-Bit.
I have a Fast Track Ultra 8R USB Audio Interface, that when I do a restart of my computer, the computer freezes and no longer works if I turn off the plate and do not start the card which consequently I get no sound on PC. what I do to stop this or comflito with this problem. help me.
Old 04-25-2012, 02:14 PM
Thanks max howarth
Old 04-25-2012, 06:16 PM
TOM@METRO's Avatar
softvoices...
Does this mean 'all is well' now?
~ tom thomas
Formerly hobotom
Pro Tools 10.3.5 HDX~HDN
HD Omni +192 I/O
Intel Hexcore i7, SSD
Gigabyte GA-X79-UD3
Reaper 4.32 ReWired
Ampex MM1200 2" 24 trk tape
MOTU 24 I/O W/PCI 424
Outboard, UREI, Eventide, Lexicon, Yamaha, TC Electronics, Orban, ART, EchoAudio, Dolby, Hughes, API, Neve, Audio Arts, BBE, Aphex, Berringer, MOTU, dbx, Allison, etc.
www.metrostudios.com
Old 11-20-2012, 12:16 AM
warped79 warped79 is offline
Not sure if this is any use to anyone (it's an old thread but I found it when I was searching this problem).
I upgraded from Pro Tools 10.0.0 to Pro Tools 10.2.3 and I had this problem.
This is what I did wrong:
1. When I un-installed my 10.0.0 pro tools installation I chose option 1 'Pro Tools Only'.
Then when I installed Pro Tools 10.2.3 I had the problem described above (I deleted all my pref's, DAE prefs, Databases, did the optimisationi and nothing worked.
To fix this I went back to control panel, and un-installed Pro Tools - this time I chose option 3 'Pro Tools, Avid HD Driver, Preferences, Databases and MIDI Device/Patch Settings'.
Re-booted my machine, ran the 10.2.3 installer, rebooted again and it launched straight up and works fine (so far).
Hope this is useful to someone out there
Daz
Old 11-20-2012, 06:26 PM
pschlacter01 pschlacter01 is offline
It definitely was for me. I've searched a lot for an answer! thanks!
Could not allocate memory for the disk cache. Try lowering your disk buffer.. slim_shady Pro Tools 10 Discussion 5 11-29-2012 05:33 AM
Trouble with buffer size when bouncing to disc nn_ss_kk Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 1 06-06-2007 07:57 AM
Playback Engine/ lowering the buffer size Jack London Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 0 03-23-2005 04:43 AM
lowering buffer rate for amplitube latency B.VanBibber Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 1 06-01-2004 06:26 PM
pro tools free freezes after lowering buffer size poyofrito Digidesign Hardware & Software 1 05-08-2003 12:39 AM
