Old 04-02-2012, 08:51 PM
jmbtexas jmbtexas is offline
Default How do I use a plugin?
I downloaded a demo of Waves CLA Vocals plugin, and it was installed, but I don't know where it is or how to open it in Pro Tools.
I don't see any "plugin" menu option in Pro Tools.
Any advice would be much appreciated.
Thanks,
Jeff
Old 04-02-2012, 09:01 PM
nst7 nst7 is offline
Default Re: How do I use a plugin?
You go to the Mix window in Protools, and on your audio track (if you don't have one, create one), near the top, is spaces for inserts, you click on one of those spaces, and it will give you a choice for plugins, and then you drag your mouse to the different categories (this one might show up under "other"), and you will locate it there.
Old 04-02-2012, 09:19 PM
nst7. Ok, I found the plug in option in the mix window, but I don't see the Waves CLA Vocal plugin anywhere on any menu option, including "other."
Any ideas on how to get it to show up?
Thanks,
Jeff
Old 04-02-2012, 09:27 PM
Ok, I see it now. I had to do activate something else from Waves after the install. Thanks!
Mega plugin deals!! Slate, plugin alliance etc crizdee AAX Plug-ins 3 02-06-2014 12:03 PM
Automation, Plugin, write-to-all-enabled, but only for the currently targeted Plugin joachim Pro Tools 10 3 07-11-2012 10:48 AM
v control (v2) plugin encoder cannot instantiate plugin screen in PT10.0.1 klyg Artist Series 2 02-29-2012 11:50 PM
Plugin Management or Selectable Plugin Sets ?? Lizardpoint Pro Tools Software (Mac) 2 04-01-2011 02:52 AM
Vocal plugin needed to change voice, what is the best plugin Logicdance Digidesign Hardware & Software 0 03-13-2007 05:26 AM
