Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Win)
Old 03-27-2012, 05:39 PM
davegibbon davegibbon is offline
Default Error Message -9514 on PT10 Launch
Hey there,
Has anybody experienced this error before:
Could not allocate memory for the disk cache. Try lowering your disk buffer (DAE Buffer), disk cache size, or engine voice count. If you got this error on launch deelte your prefs and try again. (-9514)
It's happening on launch, so I deleted the prefs and restarted. Still getting this.
We're running Win7 64-bit using a SSD system drive, which has PT installed on it.
Any help would be much appreciated.
Dave
Old 03-29-2012, 01:52 PM
sakkakth sakkakth is offline
Default Re: Error Message -9514 on PT10 Launch
I get the same error as well with PT 10 HD2 system. Running Win 7 64bit.
I have had to revert back to 9.0 as I could find no solution. Would love to know if you get a better response.
Someone had mentioned disconnecting from their domain would make it work. I am unable to try that currently since I need to get our IT dept involved and that's scheduled for next week. The new PT 10 disk cache feature that lets you use network drives does seems to be the issue... ;/
Old 11-12-2012, 07:28 PM
ReynaldoPena ReynaldoPena is offline
me three
rschoolofmusic.wordpress.com
facebook.com/rschoolofmusic
twitter.com/rschoolofmusic
reverbnation.com/rey1788
iTunes: http://itunes.apple.com/us/album/on-my-way/id274818471
Old 12-04-2012, 12:06 AM
CryingFreeman CryingFreeman is offline
Hi !
I tried to instal many times before finding why it made 9514 error.
Run setup as administrator isn't enough. You need to right click on setup and set compatibility to windows 7 + run as administrator.
And then you should not have this error anymore on windows 8.
PT 10.3.3 Error -9514 on Launch yorkshirepud Pro Tools Software (Win) 10 01-06-2013 09:46 AM
Can't launch PT 10.3.2 dae buffer issue -9514 Blackers Pro Tools 10 Discussion 3 11-28-2012 07:12 PM
-9514 error on PT10 HD2 system sakkakth Pro Tools Software (Win) 0 03-24-2012 09:14 AM
-9514 error on PT10 HD2 system sakkakth Pro Tools Software (Win) 0 03-12-2012 08:10 AM
Pro Tools 10 Launch Error (-9514) "Disk Cache (DAE)..." mgthefuture Pro Tools 10 Discussion 5 03-03-2012 08:59 PM
