Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Mac)
Old 03-08-2012, 02:29 AM
harrynilsson harrynilsson is offline
Default Track height shortcut
I'm using PT 9.06 on an intel Macbook Pro with Snow Leopard 10.6.8.
This is a problem that is occurred quite recently but I'm not sure what has triggered it.
My Ctrl Up/down shortcut to change track height of individual tracks does not work. It won't do anything. Ctrl Alt Up/down will however change the size of all tracks, so that is working.
I have looked to see if the shortcut is being used by something else (such as spaces) and it doesn't appear to be. The problem also seemed to occur on 9.05 as well.
I have also just noticed that 'Vertical zoom to show all tracks: Alt+A' is not working as it should either - it seems to be zooming horizontally instead. weird.
Appreciate any help.
Thanks.
Old 03-08-2012, 05:48 AM
PD-John PD-John is offline
Default Re: Track height shortcut
Sorry if you knew this, but when you change a single track's height using Ctrl + Up/Down, make sure the track is selected. It's easy to miss this if you're in the Edit window and "Link Track and Edit Selection" is turned off.
Old 03-08-2012, 07:53 AM
Yeah, that's not the problem unfortunately.. thanks though.
Old 03-08-2012, 08:07 AM
Stig Eliassen's Avatar
Don't know about Ctrl+Up/Down not working, but you could try Ctrl+Command+Up to fit selected tracks to window, and Ctrl+Option+Command+Up to fit all tracks to window vertically (if possible).
Also, Option+A will zoom out horizontally to show the entire session, and reset the waveform height, but will not change track heights.
Studio rig - Pro Tools|HDX 2018.3 | Logic Pro X | Avid HD I/O (8x8x8) | 6-core 3.33 Westmere w/24GB RAM | OS 10.12.3 | D-Command ES | Eleven Rack | Vienna Ensemble Pro 5
Mobile rig - Macbook Pro i7 w/16GB RAM | UA Apollo 8p | Pro Tools|HD 2018.3 | Logic Pro X | OS 10.12.6
Old 03-08-2012, 08:32 AM
Thanks for the tips - you are right about Option-A, I don't usually use that shortcut so I wasn't sure if it was working properly.. no problem there then.
The other two shortcuts you mention seem to work fine so it seems only my beloved Ctrl-Up/Down is not working. If only I could work out why. Thanks for the help.
Old 03-08-2012, 08:37 AM
Hmm, took a peek in the PT 9/10 docs, and they've changed a few things since PT 7.4. Option+A should zoom out vertically to show all tracks according to the shortcuts doc. Option+Ctrl+A should zoom out horizontally.
Old 03-08-2012, 09:02 AM
No, I'm agreeing with you about Option-A.. I got it wrong and it is working as you said.
It is only Ctrl-Up/Down that is the problem. Something is definitely wrong with that one.
Old 03-08-2012, 11:42 AM
I managed to fix it - I enabled spaces and tested out the ctrl-up/down shortcut to shift between spaces, which worked. then I disabled spaces again and as if by magic, the PT shortcut started working again!
Old 02-19-2013, 04:34 AM
mhmh mhmh is offline
I just moved to HDX and ran into the same problem, ctrl-arrow up or down won´t do anything, the other shortcuts (ctrl-alt- arrow/ctrl-alt-cmnd arrow etc.) all work. Unfortunately the trick with spaces (Mission Control) didn´t work for me. Any other ideas anyone?
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0
http://www.pelhamundhaas.de/index2.html
http://www.pelhamundhaas.de/vita.html
www.3-p.de
www.imglashaus.de
Old 02-19-2013, 04:45 AM
Solved it, the shortcuts were occupied by quickeys, "iTunes volume up and down", seems to be a default setting in quickeys 4.
www.3-p.de
www.imglashaus.de
track height jknourse Pro Tools Software (Win) 1 07-18-2012 02:06 PM
Track Height Shortcut broken cowrange 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 03-04-2012 11:01 AM
Shortcut for "default wave height" not working Jantex Pro Tools Software (Win) 5 11-17-2011 09:37 AM
shortcut for multi-track height in 7.1? Ken P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-17-2006 12:53 PM
Shortcut to reduce/increase windows height? Enrico Donner ProControl, Control|24, Command|8 2 05-21-2001 04:21 PM
