Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Mac)
Old 02-29-2012, 04:30 PM
Asar Asar is offline
Default Pro Tools 10 HD Native Input Monitoring Glitch
i noticed when i have the green "i" highlighted on a record track, but not actually recording, only sometimes it will play my mic signal through it. it seems like after i been in the session for about 10-15 mins my mic signal will come through without recording, which is what I'm used to. anyone else having this issue? i toggle back and forth with the "set record tracks to input only" and "auto input" options but its the same glitch of not working at times. please look into this and fix it avid. thanks!
Old 04-21-2012, 10:13 AM
Default Re: Pro Tools 10 HD Native Input Monitoring Glitch
issue still exists in 10.1.2 of pro tools hd. this is when using low latency mode and on a hd native card.
Old 04-26-2012, 11:32 PM
issue still exists in 10.1.3
Old 04-27-2012, 03:13 AM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Just out of interest, are you using Low Latency Monitoring?
5,1 Mac Pro Dual Hex Westermere 3.6Ghz, 24gig Ram, Pro Tools HD Native 2018.4, Sierra, Blackmagic Decklink HD Extreme 3D.
Old 04-27-2012, 07:22 AM
Yes
Old 05-10-2012, 05:21 AM
Unhappy Re: Pro Tools 10 HD Native Input Monitoring Glitch
Please look into this Avid. Driving me crazy.
Old 05-10-2012, 03:55 PM
Carl Lie Carl Lie is offline
Did you check the cable?
C
PT 2018.1 HDX OMNI+HDX8x16 -Mac Pro 12 Cores 48 GB RAM OS 10.12.5 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL-GML -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 05-10-2012, 04:20 PM
Are you using hardware inserts on any tracks feeding to the nominated LLM pair? or do you have any plugins on a master track feeding the LLM pair?
Is the Input Monitored track feeding a bus?
All of these scenarios are affecting the way LLM works for me.
Old 05-14-2012, 07:57 PM
stationwest615 stationwest615 is offline
this problem occurs to me as well. I am on PTX with the Native Card. When low latency monitoring is ON input monitor does not work. BOOOOOOOOooooooo
I seem to have figured out a work around though...
if i go to Hardware settings and change the buffer size to a smaller setting, when i retry input monitoring, it works. Even if i then change the buffer size BACK to what it was before. Not sure why.
Avid please fix this! My 002 runs smoother better than PTX!!!! why did i pay the high price for a crap product?
Old 05-15-2012, 02:48 AM
Labroue Labroue is offline
I have the same problem with the Digi003, and PT10 CPTK (+ low latency input monitoring mode).
In order to work in good conditions, I found a solution. I place in the virtual console a first input channel (this is very important that it be first); I always switches the input monitoring (light green) on this first empty track.
I do not use this first track, it only allows the system to work.
Avid Please, fix this bug.
Thank you; best regards.
Does HD native or native native disable plugins when monitoring inputs? BasketCase Pro Tools HDX & HD Native Systems (Mac) 7 05-20-2013 08:48 AM
Input monitoring IN HDX/Native or Complete Production Toolkit txshonk Pro Tools 10 18 04-30-2012 06:32 PM
Input only monitoring in PT9 Native koo_koo_bonkers Post - Surround - Video 6 04-04-2011 08:02 PM
Input Monitoring with Pro Tools 9 fenders Pro Tools 9 4 01-05-2011 05:43 PM
New to pro tools, I have an input/ monitoring question mchristofi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-14-2008 05:32 PM
