003 Rack standalone does not work in Win7
It's pretty clear now that the 003 Rack does not work in Windows 7 64 bit. The published drivers load fine and report that they are functioning correctly, but no software can see or use the interface in any manner. It seems that this is because the Digi drivers do not support 64 bit OS in Windows 7. I wish Avid would put that on the downloads page.
Am I right? Budsy |
Re: 003 Rack standalone does not work in Win7
There has been debate about the driver issue but Avid claims the problem is more to do with chipset/circuitry. The discussion continues, and the truth remains....debatable.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
My 003 Rack works fine on Win 7 64-bit...
But read my post #15 and follow-ons on this thread: http://duc.avid.com/showthread.php?p...=1#post1792191 Follow those instruction exactly, and if you still have a problem it's probably a Firewire issue. I've forgotten which Firewire driver you should use, but I think it's the "legacy" driver...search on here to double-check...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Mine works fine too Bill, but that's because Pro Tools is 32Bit.
I think the OP is referring to it working in true complete 64Bit environment. His statement "It's pretty clear now that the 003 Rack does not work in Windows 7 64 bit" is misleading though as you're right, the 003 works fine on Win7 64Bit in Pro Tools. My initial reaction was exactly the same as yours but then I thought he may be trying to use it in a 64Bit program. Maybe the OP can clarify what he is asking.
Well, this seems to be a curiously complex issue. However, note that I got my system working! I simply installed the old 'legacy' (XP?) drivers for the 002 and 003 racks. It works splendidly in my Sonar X1 Producer Expanded (x64 version). And, it works as a Windows system sound output device, a general sound card for other apps, etc. I'm happy as long as I can get sound out of this puppy.
Budsy |
hey Budsy... How did you do to do this? Can you explain the procedure for use digi asio driver v.7 (winxp) with windows 7 x64 ?
Thanks! ; D Quote:
003 Rack standalone not right in Win 7 | Budsy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-24-2012 02:00 AM |
Eleven Rack Win7 rack machine | MetalMania | Eleven Rack | 0 | 01-18-2011 09:16 PM |
Standalone ASIO drivers for Win7 x64 | kenzo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-21-2009 07:57 AM |
Win7 did definitely not work for me | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 34 | 10-28-2009 10:25 PM |
Can the 003 Rack work as a "Standalone Mixer"? | MythMuzik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-11-2009 01:04 AM |
