Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Old 02-25-2012, 09:42 AM
YichenWang YichenWang is offline
Question How to REMOVE instrumental from a track?
i use protools 8 le, and i want to know is it possible to remove instrumental from a song (keep vocal).
i know this is little bit tricky, but i have original song track and instrumental track. is there a way to get vocal only?
i just want that vocal. it doesn't matter quality (it can be very low).
-sorry about post this to the wrong area early.
Old 02-25-2012, 10:33 AM
Default Re: How to REMOVE instrumental from a track?
Still not possible. Any polarity/phase trickery will do a better job of REMOVING the vocal, not keeping it. Maybe if you explain your goal, somebody will have an idea to offer.
Gigabyte GA-EX58A-UD3R, Intel i7 950, 12 gig Corsair DDR3, PNY GeForce 210, Focusrite ISA428, Octopre Mk II Dynamic, Lucid GenX192, DIGI003 running PT10HD, Vintech and Five Fish preamps..............................
http://www.myspace.com/cswstudio
www.capricornsoundworks.com
The cool thing about digital is; there's 4 ways to do everything. The bad thing about digital is; there's 4 ways to...........
Old 02-25-2012, 12:10 PM
CME CME is offline
Default
If the instrumental an exact duplicate minus vocals (and most of the time it's not unless you did this yourself, but then you wouldn't be asking how to do this lol) you could try flipping the phase of the instrumental track and see what happens. I wouldn't hold my breathe.
There are some plugs that can adjust the width and balance of the the center vs the L/R, but those won't completely remove anything. Also there are probably other instruments panned center that would still be there.
MacBook Pro (4.1, with a 3.1 logic board, long story) 2.6 GHz C2D, 6GB Ram, OSX 10.8.2.
GA-X58A-UD3R, i7-930, AMD Radeon 6870, 12GB of RAM, OSX 10.7.5.
Pro Tools 10.3.5, Harrison Mixbux 2.2
Metric Halo 2882 2D +DSP, Metric Halo Production Bundle, Plug & Mix VIP Bundle, Slate VCC, VTM and SSD4, McDSP ML4000 and Analog Channel, AIR Strike.
Old 02-25-2012, 11:14 PM
i bought a cd has 2 track, full song and instrumental. so i think the quality of instrumental wont be a problem.
i just wanna sample the vocal. cant i just do a simple subtraction?
Old 02-26-2012, 03:17 AM
CME CME is offline
Default
You can try but I'm betting the instrumental track isn't identical just without the vocals. But if you want to try, line them up, and flip the phase of the instrumental track. If it is identical only the voice should be there. If it's not you'll get a weird comb filtered mess.
Old 02-26-2012, 06:26 AM
so could you tell me what is "flip the phase" and how to do that?
thx a lot
Old 02-26-2012, 08:49 AM
CME CME is offline
Default
You can either insert a plug-in on the track you want to flip that has a phase switch (like eq3), or I believe there is an option in the audio suite menu to do it also.
How to REMOVE instrumental from a track? YichenWang Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) 2 02-26-2012 12:05 PM
Instrumental Rock Track 11R PMcC Eleven Rack 13 02-04-2011 09:42 AM
Creating Space In Instrumental/ Vocals Sit On Instrumental walkerd96 Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) 2 10-24-2009 11:13 PM
Remove 1 Track From Group? Sparky1 Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) 6 02-15-2009 12:09 PM
Mixing and mastering with a two track instrumental Mo Yates Tips & Tricks 2 10-19-2006 06:19 AM
