Old 02-25-2012, 03:16 AM
E-Lister E-Lister is offline
Unhappy "The current playback engine does not support a sample rate of 48 KHz"
Last night I was working on a college project and everything was fine.
However, this morning every time I try and open my session I receive the following error:
Playback engine in Pro Tools is currently set to my Mbox2
The only other option is ASIO4ALL v2 and selecting this option presents the error:
"The selected ASIO audio device could not be initialized. Please choose another audio device."
Anybody have any ideas?
Regards,
EDIT: Fixed the issue, please close/delete this thread.
E-Lister
HND Sound Production - Student
Old 02-25-2012, 05:45 AM
AlainZagar AlainZagar is offline
Default Re: "The current playback engine does not support a sample rate of 48 KHz"
I think this problem usually occurs if you have another sound card or motherboard sound feature in your computer and windows has defaulted to it for some reason.
In windows 7 go to control panel - Sound then try setting the Playback to the sound card that's currently paired to the ASIO driver.
Alain
Old 02-25-2012, 11:18 AM
You might also try uninstalling ASIO4ALL. It hosed my system(but removing it solved everything).
Old 02-25-2012, 11:54 AM
Top Jimmy's Avatar
That's not quite right. This problem arises when you are using the Avid interface for default system sound and something is actually using it when you try to open Pro Tools.
The OP needs to quit any processes using the Mbox 2 and deselect it as the default system sound device.
James Cadwallader
Current Playback Engine does not support sample rate sharpo07 Pro Tools 11 7 01-08-2016 05:32 AM
"The current playback engine does not support a sample rate of 48 KHz" error when tr eyeshow Pro Tools M-Powered (Win) 19 09-09-2015 10:10 AM
The current playback engine does not support a sample rate of 48 kHz. allegrarc macOS 9 11-27-2014 09:43 PM
"The current playback engine does not support a bit rate of 48kHZ" M-powered 8 beasleymusic Pro Tools M-Powered (Win) 1 04-02-2011 03:17 PM
The current playback engine does not support a sample rate of 44.1 khz murdafew Pro Tools M-Powered (Win) 4 05-14-2010 03:21 AM
