Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Go Back   Avid Pro Audio Community > Legacy Products > Aspera DigiDelivery
Old 02-22-2012, 02:34 PM
RhodesB3 RhodesB3 is offline
Default Ethernet port #1 not working / lighting up
Hello,
Anyone have any ideas for resolving an issue with my DigiDelivery server? I am able to log in using port 2 with no problem. When I connect a cat5 cable to port 1, it does not light up. I've tried cables that I know work etc.. any thoughts???
Old 02-23-2012, 02:35 AM
Pythagor Pythagor is offline
Default Re: Ethernet port #1 not working / lighting up
Sounds as HW problem. You should probably write down your server current IP address somewhere to be able to login.
Artist Control v2 -PC with 1 ethernet port Swurveman Artist Series 2 05-07-2012 01:22 PM
Ethernet port 2 Frank Kruse Artist Series 11 01-30-2012 12:41 AM
No Ethernet port left for the Euphonix mix :( gsilbers Pro Tools TDM Systems (Mac) 7 03-18-2010 06:14 PM
Ethernet port/hub/switcher question. James Lugo Pro Tools TDM Systems (Mac) 10 08-06-2009 08:23 AM
C24 Ethernet port quit.. please help! Surth ICON & C|24 1 07-22-2006 03:34 PM
