Anyone experience the "pro tools deleted my files" behavior in PT 10?
Hello,
I am trying to decide when to make the move to PT 10, and am wondering if anyone has experienced loss of audio files after consolidating regions and closing sessions as described in this thread: http://duc.avid.com/showthread.php?t=286912 If this has been solved in PT10, it's well worth the move for me. Please folks, if you have any info, speak up. Thanks much! Peter Scherr |
Re: Anyone experience the "pro tools deleted my files" behavior in PT 10?
I would like to think that if we had any sort of serious issue with Pro Tools deciding on it's own to delete files without asking the user at least 4 times to submit a written authorization we would know about it and these forums would have like 15 threads about it per day !!!!
That is a 2 year old thread and afaic tell even back then the suspicion of 'user error' or an external hardware error was actually far greater then it being a Pro Tools issue back then. So as far as it being 'solved' ? I don't think there was anything to solve there to begin with. |
Thanks for responding...
I'm not trying to cause trouble here. Just asking for other users' experiences. My intention is constructive, and I'd like to think that the way I asked my question was diplomatic. I have been a committed pt user since '93, and plan to continue as long as I can. I'd still like to hear from other operators regarding this question. I hope that the news turns out to be good, and if so, I'll gladly move ahead to PT 10. Thank you. Peter Scherr |
Nothing wrong with your question or the way you asked it.
Maybe a more appropriate title than 'Anyone experience the "pro tools deleted my files" behavior in PT 10?' would have been 'Is Pro Tools 10 working reliable for you guys ... ?' or something like that. |
Thanks again. I can see your point. However, I do hope that a focused thread title will result in a focused response.
Getting back to the topic: In PT9, I've experienced the following behavior: • Consolidate regions across multiple tracks (typically in preparation for cross platform sharing of work) • Save session and close • On re-opening session, consolidated regions are blank and pro tools reports files missing. PT is unable to link the missing audio, and the audio can not be found using mac os finder. • Has anyone using PT10 experienced this behavior? Thanks! Peter Scherr PTHD3 9.0.2 10.6.6 plugs all up to date. Work Drives: Seagate ST32000644NS 2TB No VI's may 2008 macpro, 2 x 2.8 ghz quad core Lots of RAM |
I personally haven't seen that in 10 or indeed any previous version of Pro Tools. Could your Disk Allocation be incorrect when this occurs?
Despite you thinking that files would be written to SESSION FOLDER/Audio Files they are actually being written somewhere else on the drive? As DigiTechSupt says if this were a widespread issue the DUC would be filled with complaint threads. Sorry can't be more help. Ceri |
Seems this happened to some with Pro Tools 9 and 8 as well
Seems very random but it happens http://duc.avid.com/showthread.php?t=286912
Pro Tools Ultimate 2023.6 Logic Pro 10.7.8 macOS Ventura 13.3 MacBook Pro (16-inch, 2021) Apple M1 Max Memory 64 GB PreSonus Quantum 26x32 Thunderbolt |
I suppose it's worth mentioning that whilst I haven't done the PT10 upgrade yet, I haven't had the random file deletion after consolidation issue since the 9.0.3 upgrade. I did have it in previous versions on a couple of occasions.
I can understand why you don't want to install that particular upgrade due to the MIDI editor slowness, but I think it's reasonable to assume whatever fix went into 9.0.3 has also been incorporated into PT10. Hope that helps. |
Thanks Gents,
This behavior is not related to disc allocation procedures. Does 9.0.3 really solve this? Have you done a lot of multi track consolidation in 9.0.3? Thanks again, Peter Scherr |
BUT like I said, MIDI editor and MIDI in general got very sluggish after the 9.0.3 update in sessions with a lot of MIDI. Up to 10 tracks or so I don't really notice anything, but beyond that it gets slower and slower until it's almost unusable. So if MIDI's very important to your workflow you might be better not updating. We're around 95% audio here so it doesn't affect us too much. 2 steps forward and one back! PS, I'm a Lady actually |
"ALL" Group behavior in Pro Tools 9 | innerbooty | Pro Tools 9 | 0 | 03-07-2014 10:23 AM |
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface | eanderso22304 | macOS | 3 | 11-23-2011 06:45 AM |
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 | danball | macOS | 2 | 09-26-2011 04:49 PM |
PT 8.1 audio "hits" or "pops" when i open files from PT7... | djoeyd77 | Pro Tools TDM Systems (Mac) | 1 | 10-31-2009 03:59 AM |
Structure - what does "Monolithic" mean as it pertains to "part" files? | Jared_TL | Virtual Instruments | 2 | 12-07-2008 03:37 AM |
