Avid @ NAMM 2018
Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Win)
Old 01-11-2012, 02:16 AM
chdrummer chdrummer is offline
Default pro tools wont close out`
whenever i try to close pt 10 out it wont close. i have to manually go to the task manager and kill the process. its w7 64 bit.
it never did this with pt8 or 9.
any suggestions?
Old 01-12-2012, 09:58 AM
peter kuchar peter kuchar is offline
Default Re: pro tools wont close out`
My pt 10 takes about a minute and a half to close. I think my problem is that I have some out dated vst's I like to keep around. There are some other threads on this issue. Take all out dated or questionable plug ins out of your plug ins folder and put them in the unused plug ins folder, delete preferences(a few steps) re start and see if it closes correctly. If so add your plug ins one at a time to find the culpret!
Old 03-06-2012, 06:37 PM
imdrecordings imdrecordings is offline
Slow close down here as well.
Not sure why and I don't have any old plugs that would cause this.
Same happens when there is no session loaded.
I'm using an Mbox3 and I don't recall PT taking this long when using a third-party interface with PT10
Old 03-31-2012, 07:36 PM
Sidecut Sidecut is offline
Same here. Win 7. !0 wouldn't close unless I forced it in task manager. Now it is closing but is taking awhile and when I open it, it takes forever on "initializing databases"
Old 04-01-2012, 06:37 PM
drh1's Avatar
drh1 drh1 is offline
I can exit out of PT 10 without a problem, but when I go to shut my computer down it hangs. I always have to manually reboot, then I can shut the computer down in the ordinary fashion. I do not have that issue with any other program. I have done the PT optimizations. I do not have any non Pro Tools plug-ins. Very annoying. It would be gratifying to find a solution.
http://douglashood.zenfolio.com/
MSI X99A SLI Plus LGA2011, i7 5930 3.5 GHZ 6 core 12 threads, Kingston HyperX Fury 64GB DDR4 2400MHZ, NVIDIA Quadro K2200, LG 16x Blu-ray writer, Samsung 850 Pro 512 GB SSD for OS, three WD Caviar Black 1TB SATA 3 6Gb/s 7,200 RPM drives (audio, video, samples), EVGA Supernova 750W G2 PSU, Corsair Cooling Hydro H100I V2, W 10 Pro, 4 TB WD USB3 external backup, PT12.5.2, IK Sampletank 3, AIR IEP, Wavelab Pro 9, RME Fireface UFX w USB2 connection.
Old 04-01-2012, 09:10 PM
DaveBCC DaveBCC is offline
Same here (reported in this thread http://duc.avid.com/showthread.php?t=310911 ). I thought I had it licked when I disabled hyperthreading, but it came back almost immediately.
As to slow starting on Win7, see post 25 in this thread:
http://duc.avid.com/showthread.php?p=1712246
Old 04-02-2012, 10:57 AM
29CountsNY's Avatar
29CountsNY 29CountsNY is offline
I had a session go into the 'I can't save because of errors' nonsense and when I tried to go back in the session after forcing a reboot, PT would take 10 minutes to close every time. Whether I had a session opened or not.
I trashed all prefs, made sure my user on my Win machine had read/write access to the hard drive and nothing seemed to help.
Being bent out shape I sucked it up and went back to a previous image I had from January (I am a little behind in backing up) that I new was working since it was made after a fresh install and everything was fine again.
My logic is that there is a file that PT is having issues writing to when the program closes and that is causing it to hang. This tends to happen after I get the crap with the not being able to save issue.
But not knowing which file or even where to look I rolled back to a stable image.
The insane thing is that the next time you go into PT, it loads fine. It's only on Exit that it hangs.
Sorry, wish I had a magic cure for the DUC.
www.montabonsound.com
www.29counts.com
Pro Tools HD 12.8.3 | HD Native PCIe | HD I/O | 2 x Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Sierra 10.12.6 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v9.6 & Abbey Road Collection | V-Control Pro
Pro Tools HD2 8.1.1 | 2 x PCIe Core Card | Digi 192 | 2009 Mac Pro Eight Core 2.26ghz
Old 04-02-2012, 05:09 PM
drh1's Avatar
I notice that after I close Pro Tools and look in the Windows 7 Task Manager, it shows digiSPTIService.exe under Processes. I understand that executable is for "Pro Tools CD Ripping Service." Should that be present in Processes after Pro Tools is closed? Would that cause Windows to hang upon closing? If so, what do I do about it?
Old 05-14-2012, 07:34 AM
louieshowers louieshowers is offline
You need to do a fresh reinstall. You probably have deleted databases by following the INCORRECT STEPS provided by AVID. For some reason whenever I did this in ProTools 10, it caused the problem you speak of. Just reinstall and you will be fine.
Windows 7 64 Ultimate: SP1
PT 10.3.8
¨WHERE´S MY CHECKBOOK?¨
https://soundcloud.com/louieshowers
Pro Tools 10 HD very slow to close Audio_Vision Pro Tools Software (Win) 4 02-01-2012 04:33 PM
Pro tools wont close kingof6strings 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-14-2010 11:49 AM
Cant close or save pro tools le 7.3.1 zcustomman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-27-2007 11:41 AM
Error Trying To Close Pro Tools... The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-05-2006 03:56 PM
pro tools open and after a second they close extratone Pro Tools M-Powered (Win) 5 11-20-2006 03:18 PM
