Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Win)
Old 01-05-2012, 02:58 PM
TheVRsNo$ TheVRsNo$ is offline
Question Unsupported audio buffer size in device control panel
"Your audio device is configured with an unsupported audio buffer size. Please select on of the following supported buffer sizes in the device control panel: 32, 64, 128, 256, 512, 1024, or 2048."
^^^ This is my error message when trying to open Pro Tools 9 with a brand new Tascam US-800. My laptop is a HP DV7-4285dx. I am new to Pro Tools and this device. I've had them both now for over a week and haven't even had the option to create a new project w/ Pro Tools yet or even completely open it! But I do know the Tascam is recieving the signal
So ^ is my problem... I feel like my brain is burning from trying to figure out how/where to change my "audio buffer size" or bypass this error message and finally create a project. PLEASE HELP!
Old 01-05-2012, 03:03 PM
DarylG DarylG is offline
Default Re: Unsupported audio buffer size in device control panel
Hit "n" as you open PT. This will allow you access to the Playback engine where you can specify all sorts of stuff.
D
ProTools 9.02
2 x Intel Xeon x5675 3.07GHz Hex Core
48GB RAM
Windows 7 (x64)Pro
RME Multiface II
Intensity
ATI HD5400 series graphics card
Old 01-05-2012, 04:09 PM
Awesome! Thank you. I will try that.
Old 01-05-2012, 06:10 PM
D
Ok, so now my choices w/ drop-down menus are:
- Host Processors
- CPU Usage Limits
- Delay Compensation Engine
(DAE playback buffer (disk buffer))
- Size
- Cache size
Then has checkbox for: Minimize system memory allocation (takes effect at next restart).
WHAT TO DO NOW!?
Old 01-05-2012, 06:28 PM
Please someone help w/ my issue ^^^ Imma music guy, not a tech guy!
I know I haven't posted much here. But I've actually only owned Pro Tools for 9 days but still havent been able to create a project. I'm just a noob, I know...
Old 01-06-2012, 05:43 AM
bump
Old 01-06-2012, 06:48 AM
daeron80 daeron80 is offline
At the top of that dialog (the one that comes up when you hold down N during program launch) is a Current Engine dropdown list. That's where you choose your Tascam interface. If it doesn't appear in that list, the drivers are not properly installed.
After choosing the US-800, choose a H/W Buffer Size. In general, use the smallest one for tracking and the largest one for mixing, if needed. Small buffers give you low throughput latency but require more CPU, which makes for a better tracking experience. Large buffers take the pressure off the CPU at the expense of I/O latency, giving you more power for mixing large sessions.
David J. Finnamore
Amount of control over loudness exercised by
1. Recording/mastering engineer by reducing dynamic range: 0%
2. Listener by operating volume control: 100%
PT9.0.3 | 002R | Win7 and Mac SL
Old 01-06-2012, 10:31 AM
Top Jimmy's Avatar
Top Jimmy Top Jimmy is online now
How? Do you have this interface selected as the Windows audio device? If so, that could very well be your problem. Select something else as the default Windows audio device and try using it in Pro Tools again.
James Cadwallader
"Men occasionally stumble over the truth, but most of them pick themselves up and hurry off as if nothing had happened."
-Winston Churchill
Old 01-06-2012, 12:01 PM
I'm pretty sure it is at least. I had my mic plugged in to it and phantom power on. Plugged the headphones into the computer and I could hear my vocals from my microphone through the interface and computer into my headphones.
I will try all these things in a couple of hours when I get off work. i appreciate everyones input and PLEASE KEEP IT COMING!
Old 01-06-2012, 12:25 PM
Top Jimmy is right, as usual. If the Tascam doesn't appear in the Engine Dialog, it doesn't necessarily mean the drivers are installed right. It might be simply that the Windows system or some program has grabbed it and won't let PT see it.
David J. Finnamore
FYI: PT 10.3.3 complains about unsupported buffer size 2048 Niilo Nuori Pro Tools Software (Win) 0 02-22-2013 02:43 PM
Control Panel and Pro Tools show different buffer size (latency). birdfluvirus Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 0 05-10-2012 08:11 PM
Error at startup: "Your audio device is configured with an unsupported buffer..." Kronos78 Pro Tools Software (Win) 0 05-03-2011 12:39 PM
ProTools won't launch; unsupported buffer size DarylG Pro Tools Software (Win) 3 02-23-2011 07:07 AM
Wavedriver - sound control panel: No Audio Device misterkay Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 6 04-07-2004 04:47 PM
