Avid @ NAMM 2018
Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 10 Discussion
Old 01-04-2012, 09:06 AM
ctyelvis ctyelvis is offline
Default Difference between 8HD, 9HD & 10HD?
Is there a place I can go to read about the feature differences between the last 3 HD versions of PT?
I mean other than the ability to use HD native, what are the big advantages between the upgrades? Starting with 8HD going to 9HD, etc.
Thanks!
-Chris
Old 01-04-2012, 09:16 AM
Stig Eliassen's Avatar
Default Re: Difference between 8HD, 9HD & 10HD?
I would suggest that you download the docs for 8, 9 and 10, and focus on the "What's new in PT..." PDF's.
Pro Tools|HDX 12.7.1 | Logic Pro X | Avid HD I/O (8x8x8) | 6-core 3.33 Westmere w/24GB RAM | OS 10.12.3 | D-Command ES | Eleven Rack | Vienna Ensemble Pro 5
Old 01-04-2012, 09:25 AM
Fooks Fooks is offline
Thanks!
-Chris
well first off, from version 8 to version 9. Version 8 you needed avid pci and pcie cards, version 9 you don't have to have their hardware, you can use 3rd party usb, firewire devices, you can use other pci-pcie cards etc. Version 10 adds features on top of what version 9 has, 32 bit floating, new channel strip plug in, it brings in the new plugin format of AAX, which version 11 will get rid of the TDM and rtas formats. 10 also added clip gain, which is really nice. Should just check out PT10 on the avid website, there should be a link somewhere on that page that has a link to a comparison chart.
That is bunches of crunch!
Old 01-04-2012, 09:29 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
If you will use Avid hardware, there's not much of a difference between HD8 and HD9.
If you want to use non-HD hardware, or open your HD sessions on a laptop, then HD9 or HD10 are needed.
HD10 adds some great performance improvements, like the disk cache.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 01-04-2012, 11:29 AM
nst7 nst7 is offline
PT9 added hardly anything in features for HD users, other than the ability to use that same HD software without HD interfaces, like on a laptop, etc.
HD10 continues that, and adds disc caching, which is a huge improvement in stability and responsiveness (the more ram you have, the better), and the very good Channel Strip plugin, and a few minor things I can't remember. Oh yeah, more tracks/voices (256, up to 768 with 3 HDX cards).
Old 01-04-2012, 03:59 PM
Thanks guys.
Kinda sounds like for my little 8 core Mac, HD2 Accel setup, I may want to just stick with 8.1? Especially since the upgrade to 10 is in excess of $800. Quite a bit for the few extra features as nice as they may be.
Although the disc caching would be nice....
If I already own Heat and most of the Waves stuff including the API, SSL, "V" series, and the Ren stuff, would the new PT10 channel strip be of greater benefit or just a different flavor?
Thanks again,
-Chris
Old 01-04-2012, 06:22 PM
Actually, to upgrade from HD8 is $1500.
As for the Channel Strip, it's very nice, but not essential.
Old 01-05-2012, 12:18 AM
JFreak's Avatar
JFreak JFreak is offline
I have HD 8.1.1 and 10.0.0 set up and while I love the new 10 features such as disk cache, realtime fades and clip cache, I have no problem reverting to 8 when I mix in front of audience. HEAT is available for both, plugins are equally compatible, all I lose is the ChannelStrip.
On a wider perspective; here's the history timeline:
- PT5 was using classic Mac OS. MIX and HD hardware supported.
- PT6 brought Protools to OSX (Jaguar/Panther). Last MIX version was 6.4.1 and after that the development focus moved to MIDI.
- PT7 brought multicore plugin processing and Intel-Mac support. Special 7.4.2 version built as transition software between Tiger and Leopard, but I would keep using Tiger if possible.
- PT8 brought a new GUI and is a transition software between Leopard (8.0/non-HEAT) and Snow Leopard (8.1/HEAT). Everything since 8.1 obviously requires pci-express cards on OSX because SL is Intel-only.
- PT9 can be used with whatever hardware runs on Snow Leopard. Lion support is there but I would keep using PT9 on SL if possible.
- PT10 is a transition software between TDM/RTAS and AAX plugins. Everything work in 32 bits. Clearly this is built with Lion in mind, although runs on SL as well.
- PT11 likely drops TDM/RTAS altogether and goes 64 bits, only supports AAX.
Use what you need, not what you want to
Janne
Old 01-05-2012, 04:15 AM
J,
Nice chronological break down of the PT time line!!
Hey man, thank you for taking the time to do that!!
I had only gotten onboard HD at the tail end of vers. 7.4, so all that historical info was extremely interesting!!
By the way, I can see them dropping TDM, but do you guys really think they would drop RTAS or native in general as well? What would be the replacement for the LE stuff, which is a very important bridge to the HD side of the PT universe?
Thanks again!
-Chris
Old 01-05-2012, 04:33 AM
mattrussell mattrussell is offline
chris, both TDM and RTAS will indeed be gone soon and they're being replaced by the 'unified' format of AAX. you can read more about it here:
http://www.avid.com/US/products/Pro-Tools-HDX/features
m
http://www.gainstructure.com
10HD CPU difference pasanta Pro Tools 10 Discussion 5 01-27-2014 01:03 PM
Need upgrade to PT 10HD only brickroadstudio Pro Tools 10 Discussion 9 12-17-2013 03:28 PM
Wtb: Pt 10hd Alex TCH Buy & Sell 0 06-19-2013 09:44 AM
10 to 10HD upgrade Alex TCH Pro Tools 10 Discussion 10 02-15-2013 01:50 PM
PT 10HD and Control 24 ? Firechild Pro Tools Software (Mac) 5 03-12-2012 02:22 PM
