Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 01-03-2012, 10:27 AM
jeffde jeffde is offline
Default DAE errors -9060 and -9507 with Pro Tools SE
Hello, I have pro tools SE whit m-audio fast-track, no problem installing but when I record or I play a record an error occur and my pro tools crash or just not let me listen to the track or just record them, I have go to other forum but none of them have successful respond. The error is DAE -9060 or DAE -9507.
my computer specification is:
-Intel dual core i3 whit 3.0 ghz
-4 gb of ram
-Windows 7 64bits
-HD graphique
-audio:realtek digital
I really need help I have buy a new computer just to run pro tools, I need it to work . Thanks
Old 01-03-2012, 10:28 AM
Default Re: Heeeeeeeeeeeeelp please
sorri if i'm not in the good part of the forum
Old 01-03-2012, 05:53 PM
PapaK PapaK is offline
Default Re: DAE errors -9060 and -9507 with Pro Tools SE
Hey Jeff, I'm a new ProTools SE user, running on a new Toshiba Laptop, 2.6Ghz, 4GB RAM and Windows 7. I was also getting multiple DAE errors after I would record a track and then try and play it back. I ran a compatibility check by right clicking on the PT icon, it then directs you to start PT. On my system it found something that was not compatible and it switched something to a Windows XP environment and now everything works great.
I'm trying to find out why it didn't like Windows 7 since the latest version of PTSE is suppose to be compatible. I'm considering downloading and installing the Service Pack 1 for Windows 7 to see if that makes any difference.
Anyway, try the compatibility checker and see if it helps
Old 01-05-2012, 07:36 AM
thanks I will check that option
Old 01-06-2012, 01:57 AM
tomassito74 tomassito74 is offline
I had smilar errors but they seem to disappear when I checked "disable host control" in the preferences of my mix table...
Not sure it can help but in any case.
Cheers.
Old 02-22-2013, 10:24 PM
kpeezy kpeezy is offline
Lightbulb Re: DAE errors -9060 and -9507 with Pro Tools SE
Idk if ur still having this problem but for anyone having problems still, I was havin the same problem unil i opened up a new session but instead of empty session I clicked vocals on the main menu, I recorded some test vocals on there and the playback went fine. then i returned to my original project and it worked fine. hope this heps dudes really i felt obbligated to come and spread the word
PPC G Drive - DAE Errors 9060 9031 9060 on playback qwertyuiop Pro Tools TDM Systems (Mac) 8 09-18-2015 03:09 PM
DAE error -9507, DAE error -9060 d0miscient Pro Tools SE and Essential (Win) 2 02-13-2013 07:14 AM
DAE errors 9507, 9031, and 9060 acvdmlac Pro Tools SE and Essential (Mac) 1 06-16-2012 04:47 PM
DAE Errors 9507 & 9531 lsb3user Pro Tools SE and Essential (Win) 0 10-10-2010 10:09 PM
many errors- fatal errors and 9060 error. Sandra report inlcuded.. bradykrzemien 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 09-16-2009 12:56 PM
