Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Win)
Old 12-15-2011, 05:31 AM
hooks4hands hooks4hands is offline
Question Pro Tools 10 & Edirol UA-25ex - can't load PT10?!
Recently purchased Pro Tools 10 for use with Edirol UA-25ex usb interface.
System;
Windows 7 Ultimate 64 bit
i7 2600k
8Gb RAM
I went through the usual steps - installed latest W7 64 bit drivers for Edirol, installed PT10 from the dvd, installed instruments, installed latest quicktime, plugged in ilok and opened PT10
After about 10-20 seconds the following error msg appears;
"pro tools hardware is either not installed or in use by another program"
The only option I have is to click ok and PTools quits. If I try the hold N option while starting PT I get to the window where I can choose either PRO TOOLS I/O or the UA-25ex as my device but either option causes PT to quit.
I have tried changing settings in windows sounds to both allow and disallow applications to take exclusive control of my Edirol - same result PT won't load.
I installed ASIO4ALL and Pro Tools will start but I can't switch to my Edirol in Playback Engine menu?
Any help would be great, I wonder if maybe the interface isn't supported even though - and I quote - the Pro Tools 10 info page states;
Or pair Pro Tools with any other audio interface that supports any of the following drivers:
ASIO
Core Audio
MME
Multi-client
WDM
Old 12-15-2011, 06:34 AM
Flavor4Daze Flavor4Daze is offline
Exclamation Re: Pro Tools 10 & Edirol UA-25ex - can't load PT10?!
Don't know much about the Edirol UA-25ex, but looking at the back online. I see there is a sample rate, comp/limit type and advance driver switches in the back. I would try playing with those setting and see if that helps.
Old 01-11-2012, 02:55 AM
protoolsuser17 protoolsuser17 is offline
Default Re: Pro Tools 10 & Edirol UA-25ex - can't load PT10?!
I have exactly the same problem with my Edirol UA25!
did you find out why it doesn't work? I downloadd asio4all and had the same problem as you too!
A reply would be much appreciated. I don't mind if I have to buy another interface :)
Old 02-28-2012, 12:53 PM
tomas72 tomas72 is offline
Hi, same problem here with edirol ua 101 ...
i cannot start pro tools, always the error message :
i asked support for help, 2 weeks ago and getting no answer, just a f**** number.
Its my first time with pro tools, i thought pro tools is professional!?
pro tools is announced to work with other soundcards (asio)
i cannot belive that!
for 555 € a donlge and a description how to download pro tools....
thats all??
no support since 2 weeks!?
i am very angry...thats no good start avid!
Old 01-03-2013, 09:18 AM
zolko zolko is offline
Confirmed. Edirol UA25 and PT10 do not work together, but is it Avid fault? Focusrite guys updated their drivers to make them compatible, right? Looking for some nice USB2 or FW interface here http://avid.force.com/pkb/articles/e...ility/en422327 ...is there any newer list?
I was considering TC Impact Twin but their drivers is even older :)
PT10 Cross grade won't load Maars Pro Tools Software (Mac) 4 03-19-2013 01:47 PM
Strange noise wit both ua-25ex and focusrite usb interfaces stephenthemartyr Pro Tools Software (Win) 0 11-25-2012 03:21 PM
CPU load changes with PT10 kw88keys Pro Tools Software (Win) 5 10-24-2011 10:21 PM
PT10 CPU Load? WKG Pro Tools 10 Discussion 5 10-24-2011 10:03 PM
PT10-does it load to ram or not on LE version? PMoshay Pro Tools Software (Mac) 2 10-23-2011 03:56 AM
