Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Win)
Old 12-13-2011, 05:12 PM
Paintedeyes Paintedeyes is offline
Default Dual monitors issue
I installed Pro tools 10 on my windows 7 machine and I have dual monitors. I like to have the edit window in one monitor and mix in the other monitor which was fine in all other pro tools I am unable to do so with pro tools 10. anyone else experiencing this or know of how to fix? It could be something so easy that i'm missing.
Old 12-14-2011, 12:49 AM
matthias.matthias matthias.matthias is offline
Default Re: Dual monitors issue
What do you mean by being unable? What is the exact problem?
I had some issues initially because PT would forget window settings with each start. I figured out that when dragging the window to size it, I had to be careful not to make it too big (not bigger than the two monitors). That easily happens when dragging right up into a corner. Now everything works fine.
FR: MIDI Playlist View
Old 12-14-2011, 08:57 AM
TOM@METRO's Avatar
I run 3 monitors with PT10 just fine. Don't forget to close using alt+f4 to save your settings. You could also email "Bob Nagy @ aol dot com" and ask for a demo of "Skootch". This software will help with the issue.
~ tom thomas
Formerly hobotom
Pro Tools HDX~HDN 2018.4
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 12-14-2011, 09:09 AM
airon airon is offline
Skootch works fine with PT10 ?
I'm using v4.1 here, and it's working fine with PT 9.05 .
"My ego comes pre-shrunk" - Randy Thom
Old 12-14-2011, 09:45 AM
TOM@METRO's Avatar
Yup. It's fine in 10.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 02-05-2012, 04:49 PM
Chris182 Chris182 is offline
I'm having the above problem...I'm new to ProTools...but I'm pretty sure I should be able to just drag the Mix window on to my extended desktop monitor?
Strangely enough...the Plug-ins will drag over...but not the Mix window or the Edit window...Apologies if I'm being a noob. But the help would be appreciated!
Old 02-05-2012, 07:55 PM
Benoni's Avatar
Benoni Benoni is offline
You need to drag the back (gray) container window across both screen.
Brian
Windows 10 Pro 64 Bit
Pro Tools 2018 | Eleven Rack + ERXP
Youtube Channel - BenoniStudio
Free Eleven Rack Tutorials, Rigs, and more
@BenoniStudio
Instagram
Old 02-05-2012, 08:43 PM
That's the ticket. To get down to the basics(in case you're still fuzzy on this), start with Pro Tools NOT maximized on one screen. Now drag the edges of the main window to fill both(all) your screens. The drag the MIX and EDIT windows to the screen where you want them and drag the edges to fill the screens. Now close this session(and Pro Tools) with the Alt-F4 command.
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas..............................
www.capricornsoundworks.com
Old 02-05-2012, 10:32 PM
imdrecordings imdrecordings is offline
You have to wonder why we have to do this on a Windows machine, when Pro Tools in OSx allows you to float windows on multiple screens, without having to pull the main window all the way across all screens. I prefer the way the PT operates in OSx and wish the same window layout would carry over to Win 7. AVID???
Old 02-06-2012, 05:13 AM
sw rec sw rec is offline
You only have to set it up once, though, then as they said, close with alt-f4. My windows AlWAYS open exactly where I left them.
Dual Monitors? mix_master_adam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-27-2005 12:50 PM
5.3.1 & XP with Dual Monitors.... seanhupe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-01-2003 09:18 AM
Dual Monitors? Sabe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-24-2002 12:58 AM
Dual Monitors....please help msglider 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-17-2002 05:10 PM
Anyone using Dual monitors on the 001? Gremz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-15-2000 01:14 AM
