Avid @ NAMM 2018
Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Mac)
Old 12-03-2011, 10:28 AM
billborg billborg is offline
Default ProTools 10 Backward Compatibility?
When saving a PT10 session as a PT 9 session, there were changes to the actual audio file levels in some instances when opened in PT 9. No I didn't use any backwardly incompatible functions in 10 (like clip level). Some, not all files, were at a level that looked like they were "Normalized". Every place the root file was repeated in the sequence as a clip, the clip was at full level (nowhere near the original level in PT10). When re-rendered in PT 9 to a lower clip level (using "Gain Plugin; -24dB in some cases) the mix automation seemed fine. So this seems to be file related in the "save session copy in PT 10 as PT 9....". Anyone else find this?
Old 12-03-2011, 04:46 PM
whitewrabbit whitewrabbit is offline
Default Re: ProTools 10 Backward Compatibility?
I have been converting and back converting for the past two months without any such problems. what are you back converting to? (pt 6,7,8,9?) and on what os?
Old 01-09-2012, 12:04 PM
waylandprod waylandprod is offline
I'm having issues as well. When saving a copy as from a Windows system with Pro Tools 9 compatibility, the session will crash on opening on a mac. This has happened from various other computers as well. And it's repeatable.
PT Backward Compatibility?? Mr. Kelly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-26-2010 11:06 AM
Backward Compatibility with PT8 to PT7 ecovindaloo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-06-2009 09:06 AM
Backward Compatibility Third Eye Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-03-2004 03:33 PM
Backward compatibility of HD ^Tripper^ Pro Tools TDM Systems (Mac) 9 03-18-2002 01:34 AM
Backward compatibility of HD ^Tripper^ Pro Tools TDM Systems (Mac) 0 03-13-2002 08:59 PM
