Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Win)
Old 11-13-2011, 04:56 PM
479succeed 479succeed is offline
Default How do i change my buffer size?
Purchased pro tools 9. Installed program but i am receiving a message stating
THE AUDIO DEVICE IS CONFIGURED WITH AN UNSUPPORTED AUDIO BUFFER SIZE. Go to the device control panel and select one of these sizes (32,64,128,256,1024,2048)
1. How do i locate the device control panel to select the proper size?
2. And what is the proper size?
Using an in tell computer with Windows 7
Any help is truly appreciated.
Old 11-13-2011, 05:20 PM
Default Re: How do i change my buffer size?
this has to do with your audio hardware. what interface are you using to get in and out of pro tools?
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
Old 11-13-2011, 05:24 PM
Default How do I change my buffer size?
Purchased pro tools 9 for my intel which uses windows 7. once installed i received an error message statin:
THE AUDIO DEVICE IS CONFIGURED WITH AN UNSUPPORTED AUDIO BUFFER SIZE. GO TO DEVICE PANEL AND SELECT ONE OF THESE SIZES (32,64,128,256,512,1024,2048)
1. How do i locate the control panel to change the buffer size
2. What is the proper size to change it to
Any help would be appreciated
Old 11-13-2011, 05:27 PM
pre sonus
24bit/ 96k firewire recording interface
firebox
Old 11-13-2011, 06:09 PM
Originally Posted by 479succeed View Post
pre sonus
firebox
Open the utility for the Firebox and select one of those buffer values(you may need to select the same value in Pro Tools). There are often some little hurdles to using 3rd party interfaces
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas..............................
www.capricornsoundworks.com
Old 11-13-2011, 06:32 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: How do I change my buffer size?
First try Pro Tools>Setup>Playback Engine. Start by selecting higher buffer size then try incrementally lowering.
Generally speaking, low buffers are better for recording (lower latency) high buffers are better when editing (less taxing on computer resource).
It might help to give some more info on what outboard equipment you're using and your computer spec's;
Windows users need to provide a Sandra report
- Please - Use SiSoftware's Sandra Lite application to generate a full system profile:
www.sisoftware.co.uk
Under SiSoftware Sandra, click on "Download & Buy" to download the free Sandra Lite version or purchase other versions. After installing Sandra, click on the 'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the DUC.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Old 11-13-2011, 07:26 PM
just set it in the software for firebox. typically 64 for tracking and might raise it to 1024 for mixing depending on the power of the computer. it will automatically set these parameters in pro tools as it will slave to the hardware.
pro-tools-pc.com
Intel I7 6800k
Win 10
Old 11-14-2011, 12:06 PM
I have the Miko it uses presonus"FIREBOX' 24bit/96k firewire recording interface
Is this system even compatible with pro tools 9?
Old 11-14-2011, 12:12 PM
Problem is I don't know how to step by step change it in the firebox. brand new to the whole system.
Old 11-14-2011, 12:14 PM
I can't even get into pro tools at all. it is saying i have to change the buffer size in my hardware before i can even enter the program and i do not know step by step how to do so.
Cant change buffer size shea Pro Tools 11 0 01-16-2014 11:38 AM
So, When change H/W Buffer Size...... gonsdeejay Pro Tools 11 0 07-29-2013 09:12 AM
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! Nickford Pro Tools Software (Win) 0 05-26-2013 11:20 AM
Can't Change Buffer Size? sajack23 Pro Tools Software (Win) 5 08-05-2012 05:29 PM
PT9 / Buffer size won't change narapo Pro Tools Software (Win) 3 08-15-2011 02:59 PM
