Old 11-12-2011, 09:04 PM
AlainZagar AlainZagar is offline
Default VEPro - Aria - Multi not working the way I think it should in PT9
Hi - I know I could ask this over at the VSL forum but I suspect something with my PT9 setup is causing the problem.
I have a project with 3 VEPro instruments. When I open an instance of VEPro and add the Garritan ARIA Multi as an instrument, it seems to load correctly however I can not assign analog output channels. The only option is 1/2 and the others are greyed out. I tried both 32 and 64 bit VEPro server with 32 and 64 versions of Aria Player and I swear it used to work before. I even have a project I worked on a year ago that is configured to route these outputs to AUX tracks. So I'm pretty certain this worked before.
I created a new project with only one instrument - VEpro and problem persists.
Further trouble shooting with same Aria DLLs in VSTHost - works. I can assign all the channels to their own specific Analog outputs.
Anyone have any ideas?
Old 11-13-2011, 08:00 AM
Default Re: VEPro - Aria - Multi not working the way I think it should in PT9
update
RTAS version of Aria works ok as Multi.
So this is looking like a VST problem with ARIA and VEPro not setting it up properly to route the channel outs in the Multi version.
So looks like this may have little to do with PT9.
I'll try my luck with VSL forums.
Pro Tools 8.0.4 with Aria Player Plugins Finale 2012 FrankCan Pro Tools 10 2 08-06-2013 05:44 PM
VEPro and 11 Users... How's it working for you? Jon_Atkinson Pro Tools 11 13 07-06-2013 03:01 AM
VEPro & PT & ADC musicman691 General Discussion 0 03-06-2012 04:58 PM
Garritan Aria Player Question Julia B Virtual Instruments 0 01-12-2011 02:25 PM
PT 7.2 Multi-Channel Pans Automation Not Working???? Floydio Pro Tools TDM Systems (Mac) 0 07-20-2007 02:46 PM
