ASIO Reset Request
Has there been anymore development with the ASIO Reset Request with some 3rd party interfaces?
I have a TC Electronic Studio Konnekt 48 and this is becoming increasingly annoying and making it very difficult to work, along with countless other problems I have been having since upgrading from 9 to 10. I found this post: Quote:
where DTS says its being looked into. That post is almost a year old now so I am wondering if it is still being looked into or if there has been any developments with it. Has anybody found a work around for this in Windows 7? |
Re: ASIO Reset Request
Does anybody know anything about this? DigiTechSupt, care to chime in here?
Anything?
One more time. DTS care to look into this?
bump, please. Alesis mastercontrol and high frustration. does this also with motu 896hd.
DTS?
Intel i7 930 2.8ghz, dual 500gig raid 0, 1 tb audio drive, ati radeon 5560, M-Audio Projectmix io, Motu 896 HD through adat |
Another one. TC Impact Twin.
Lots of different PC hardware combinations are possible. You for sure will get ASIO errors if your PC is configured to use "system sounds." These should be disabled. This is not a unique problem to Pro Tools. The ASIO protocol has been around (for me anyway...) for about a decade, so the weirdness is most likely caused by the system sound card competing for an "interrupt" with a DAW card or interface. Built-in sound cards sometimes operate at 32MHz (instead of 44.1 or 48, etc.), so when Windows says, "play a beep whenever the user tries to enter an invalid selection" (which in "DOS" was CTRL-G), ASIO will be funkified and not know what the correct sample rate is supposed to be.
To make things more complicated, there are different FW and USB interfaces, both on-board and add-on, that can muck up digital audio. If all this seems needlessly complex, it is back to the argument "I'm a Mac!" vs PC open technology. |
I also havent used system sounds in years. My main concern is Cubase doesnt have this issue, so it is clearly up to Avid to sort this out. I love protools, but stability is king for me. If this gets sorted Cubase is up for sale, but until then i need to keep it around for stable tracking.
I have a separate thread posted, but I'm having problems using a Focusrite Saffire Pro 40 which is supposed to be compatible with PT 9/10. If I start PT10 with my MAudio Fastrack Ultra 8R, I get the error message "ASIO Device Properties Have Been Changed by the dvice control panel. Pro Tools must be restarted for changes to take effect". I restart PT10 and it's happy with the Fastrack Ultra 8R. However, if I start PT10 with the Saffire Pro 40, I get a pop up message to change, and I change to "Saffire" then I get the message about ASIO Device properties have been changed and to restart Pro Tools. I restart Pro Tools but get the exact same error message and can't get any further with the Saffire Pro 40. If I go back to the Fastrack Ultra 8R, I get the error message the first time I start PT, I restart it and it's "happy".
Fortunately I have a 30 day trial version of PT10 and I got it to see if my Saffire Pro 40 would work OK, and unless someone can sort this out I won't be upgrading from MP9 to the full PT10. I can use my Saffire Pro 40 without problems in Sonar.
PT MP9/Sonar X1 Ozone 5 Member of Nashville R.O.P.E. Assn. |
Ableton "Failed to open the ASIO device ASIO Digidesign Dvr" | my808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 08-28-2012 08:56 PM |
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. | scottthafoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 04-19-2010 01:45 PM |
Playlist # and track # reset request missing feature | Seti Orion | Pro Tools TDM Systems (Mac) | 3 | 11-26-2007 06:11 AM |
feature request: adc & asio direct monitoring | fizzler | Pro Tools M-Powered (Win) | 2 | 10-31-2006 11:33 AM |
ASIO driver for Digi 002 rack - help request | gear444 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-01-2004 07:48 PM |
