Avid Pro Audio CommunityHow to Join & Post • Community Terms of Use • Help Us Help YouKnowledge Base Search • Community Search • Additional Resources |
What the hell does this mean:
"Could not create a new document because Assertion in "/Volumes/Development/ws.Ludwig/AlturaPorts/DFW/MacBuild/../Views/Umenu.MacOS.mm", line 1350?" |
from http://duc.avid.com/showthread.php?t=54888
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements Thank you, Craig |
Thanks!
In Pro Tools 10.0.0 the volumes and database folders appear to be in the Avid tree in the Application library.
Emptying the Volumes folder then emptying the trash followed by a reboot doesn't appear to solve the issue. I did not find any folder under Digidesign Databases. Any ideas? |
I posted this on one of the other threads:
I am on PT 10.0.1 running Mac Snow leopard and I got the same error. Try, as dumb as this sounds, changing your playback engine in the setup menu to built in output. I just had the same error and it fixed it. Don't try to launch a new session. Simply launch PT, close all error dialog prompts , and change the playback engine. Hope this helps. |
Hey, same problem, running Lion on a MacBook Pro.
Deleting the folder didn't work, and although changing the playback engine works, I need to use the Pro Tools Aggregate I/O as the playback engine in order to use my Peavey PV8 USB mixer in PT. Any advice? Thanks in advance :) |
Hold down the "N" key while starting up Pro Tools.
Then you should be able to select Pro Tools Aggregate I/O as the playback engine in a pop up window. After that the normal Quick Start window should appear. |
Old thread but just helped me installing PT10 on OSX 10.8.4
Changed the playback engine and all good ![]() Many thanks for the heads up!
Cheers Have a good one! Northwinds |
PT 11.1.2 and 10.3.8 can't create new document | bdeivert | Pro Tools 11 | 14 | 06-24-2014 06:53 PM |
Could not create new document because assertion | angelstrack | Pro Tools 11 | 5 | 11-03-2013 01:08 PM |
Could not create a new document because... | ginthepartisan | Pro Tools 10 | 7 | 08-27-2013 07:28 AM |
''Could not create a new document because...'' | lanstrad | Pro Tools Software (Mac) | 0 | 05-05-2012 10:34 PM |
"Could not create new document because: (-51) HELP | bluesigns | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-05-2004 06:26 PM |
