Old 11-02-2011, 11:51 PM
broken81 broken81 is offline
Default Buss window is getting chopped off.
The bottom of my buss window is getting chopped off. I will post a screen shot and you can see the if you look at the bottom and then the top of the next column. It jumps from buss 38 to 43 and then on the next column 80 to 85. Any idea how to fix this so i can see all my busses?
http://dl.dropbox.com/u/610605/Pics/BUSS%20PROBLEM.jpg
Old 11-03-2011, 01:36 AM
DigiTechSupt's Avatar
Default Re: Buss window is getting chopped off.
Interesting one. So if you move the mouse down all the way to the bottom of that bus window it does not scroll either ?
One thing to try, can you (temporarily) change the screen resolution to something else and then back ? See if that changes or happens at different screen resolutions as well ?
Can you also post your system details, specifically graphics card and screen resolution ?
Was this an issue on Pro Tools 9 as well on the same system ?
Thanks
Avid Audio Tech Support
Support FAQ
Old 11-03-2011, 01:37 AM
going to move this to the Pro Tools 10 Windows section
Support FAQ
Old 11-03-2011, 03:05 AM
This was not a problem in protools 9. First thing i tried was moving my mouse around by the bottom and nothing changes.
Video card is Ati Radeon x1550
Resolution is 1920x1080 right now.
Old 11-03-2011, 03:35 AM
can you try a different resolution and see if that changes anything ?
Support FAQ
Old 11-03-2011, 03:44 AM
Works fine now and i did not even change the resolution. You have to love computers.
Thanks for the time!
Chopped waveforms SofaKing 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-18-2007 11:42 PM
edit the entire file after it's been chopped will the moor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-19-2005 12:11 PM
chopped and screwed dat Tips & Tricks 3 07-02-2005 03:18 AM
Playing chopped loops thru a MIDI keyboard - Help! alkaline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-19-2004 04:24 PM
Chopped audio playback UTS Pro Tools TDM Systems (Mac) 4 03-08-2002 06:09 AM
