Old 10-28-2011, 10:44 AM
simonchase simonchase is offline
Default What's the difference between HD Native and HDX?
1. Plug in count
2. One can use 3 HDX cards but only one Native card
That's it
Am I wrong?
Does the HDX card have a larger maximum delay compensation?
Does the HDX contribute to the mix engine?
Does the HDX contribute more voices?
Thanks!
PT12.8.3 - HDX - OMNI ---- MacOS 10.12.6 - Mac Pro (Mid 2010) - 2 x 3.46 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 RAM - SSD Startup Disk ---- AJA Kona LHi PCIe
Old 10-28-2011, 10:59 AM
nst7 nst7 is offline
Default Re: What's the difference between HD Native and HDX?
Delay comp is the same for both systems, with PT HD 10.
Each HDX card can do 256 tracks. So one would be the same as HD Native, which is also 256 tracks with PTHD10 (not with HD9). The advantage being that with HDX you can expand up to 3 cards, with HD Native, you can't. For most music users, 256 should be adequate. Post Production users on large projects may appreciate the larger track count.
HDX handles both mixing and plugins, with the option to offload some processing to the computer. HD Native handles neither of those. What HD Native handles is the I/O, which still takes a significant load off the computer, allowing you to run larger track counts/plugins at lower buffers than you could with the typical firewire/usb interface. It also allows lower latency at the same buffer than those interfaces for the same reason.
Old 10-28-2011, 11:06 AM
Rich Breen Rich Breen is online now
Originally Posted by simonchase View Post
1. Plug in count
That's it
Am I wrong?
Thanks!
Latency is the big one - the ability to track through plug-ins while generating multiple headphone mixes, etc... without significant latency is a huge issue, and no native rig can deliver this at the moment.
best,
rich
rich@richbreen.com
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 10-28-2011, 11:13 AM
brickroadstudio brickroadstudio is offline
IM running a native card on a 12 core mac pro.
I use the aviams to provide multiple head phone mixes per person recording (we have 5 boxes)
This set up allows me to have almost zero latency while tracking at 64 buffer with plug ins on...
Check out the Aviams, its a great way to have customer controlled headphone mixes without relying on host or cards. and its cheaper.
Old 10-28-2011, 11:15 AM
Thanks for the replies
Is this info anywhere on AVID's site?
Old 10-28-2011, 11:23 AM
blairl blairl is offline
best,
rich
This is a HUGE bonus for HDX systems. Not only the overall lower latency to start with, but the fact that sessions with extremely large track counts running countless plug-ins will NEVER have to have the buffer size bumped (thereby losing low latency) to compensate for the increased load on the CPU. HDX users will also never have to deal with the "zero latency" hardware workarounds.
Old 10-28-2011, 11:43 AM
But what are you using to source the Avioms? If those sources are *through* the HD-Native record path (which is the most efficient and intuitive way to run a cue mix) then you are subject to the delays of the host, unable to monitor with through plug-ins, and dependent on buffer settings controlling throughput latency. Or am I missing something? I don't own an HD-Native rig, but am interested in how it performs.
best,
rich
rich@richbreen.com
Old 10-28-2011, 11:49 AM
By tracking with a 64 buffer, he still can track with plugins, just like LE users can.
Old 10-28-2011, 11:58 AM
Yeah, in my experience, that's too much latency for the musicians I work with.
In any case, I'm still interested in exactly what he's sourcing the Avioms from.
best,
rich
rich@richbreen.com
Old 05-10-2013, 12:03 AM
garnoil garnoil is offline
someone suggested that "HDX handles both mixing and plugins"
Does this mean that the HDX card 'processes' any plugins that are running Native? or does the HDX card "only" process plugins that are AAX DSP?
I am ready to buy either HDX or Native but all my plugins are Native and not HDX. Plugins I use may never be HDX DSP for example: CEDAR, Equality, Convolution Verbs, anything Waves, etc. So, if the HDX card does not process plugins running native, for me, there is no advantage for going HDX.
As far as mixing: Does HDX process all mixing instead of the host computer? or do both HDX and Native process mixing the same way.
Is there a difference between AAX Native and AAX 64 bit? rockguitarist1255 AAX Plug-ins 7 12-30-2015 02:00 PM
Performance difference between Native and HDX jjnssn Pro Tools HDX & HD Native Systems (Win) 27 09-21-2012 02:33 AM
What is the difference between HD Native & HDX ritb General Discussion 25 08-10-2012 08:34 AM
Native, RTAS... What's the difference? Che_Guitarra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-17-2008 07:11 AM
waves native and TDM Difference jwbyrd16 Pro Tools TDM Systems (Win) 0 06-03-2003 01:43 AM
