Avid @ NAMM 2018
Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Mac)
Old 10-23-2011, 09:31 AM
denka's Avatar
denka denka is offline
Lightbulb "Could not create a new document because assertion in..."
First problem with PT 10:
At the end of PT 10 star-up process I get error: "Could not create a new document because assertion in..."
http://imageshack.us/photo/my-images...1023at601.jpg/
Trashed db, prefs, everything, repaired hd permitions, restarted Mac, still no go.
Anything else I can do before reinstalling PT10?
AVID HD Native PCIe + HD OMNI; Digidesign 192 I/O (2x) & 96 I/O; Icon QCON Pro & QCON EX; Softube Console 1; NI Kontrol 25; Arturia SparkLE; UAD-2 Satellite DUO; UAD-2 PCIe DUO; Tascam DA-3000; TK Audio BC1-S; Warm Audio WA76; SSL XLogic Alpha Channel (x2); SSL X-PATCH; Lindell Audio 6X-500, 7X-500 & PEX-500 (all x2), lots of TCE & Lexicon reverbs; VintageMaker LittleOne 16/2 Summing Mixer; MUTEC MC3+ SmartClock; Mac Pro (2009) 8 Core 2.26; 24 Gb RAM; Pro Tools HD 12.8
Old 10-23-2011, 10:00 AM
denka's Avatar
Default Re: "Could not create a new document because assertion in..."
Restarted Mac again and PT runs normally.
Maybe I have Gremlins in the Mac
Old 11-13-2011, 11:25 PM
muzackfreek muzackfreek is offline
I am getting the same error on PT 10 and I trashed everything the avid site suggested. Pt 10 is still coming up with the same error . I have also unistalled and reinstalled PT 10 about 6 times. Can someone pleas help me?
Old 01-05-2012, 09:51 AM
mattmanix mattmanix is offline
I had this error on my initial startup of PT10. Repaired permission, trashed incompatible plugins, used the "ProTools Pref and Database Helper" app (look it up) restarted several times, no dice. I finally got it to work doing this. Hold down "n" while starting PT (which I guess is standalone mode from what I've read). I pressed "n" before I launched PT and held it down until I got a dialog box asking to create a new session, etc. It started up no problem and asked what playback engine I wanted to use. Can create new sessions on start now and open up older sessions. I haven't had to start PT up using this process again since I did it the 1st time. Haven't gotten to put it through the ringer yet, but will re-post if I ever run into an error like this again. Hope this helps.
Old 04-15-2013, 02:39 PM
xbook xbook is offline
You just saved me lots of frustration, thanks for posting this fix. Worked for me.
Blah blah blah....grumble grumble....woo hoo woo hoo.....dig it?
Old 04-15-2013, 04:25 PM
musicman691 musicman691 is online now
What holding down the 'n' key on startup of PT does is allow one to select the audio device to be used. It overrides anything you may have selected before or got messed up.
Jack
QAPLA!
Old 04-25-2013, 01:18 PM
zeze zeze is offline
Thanks a lot mattmanix!!
Creativity is allowing yourself to make mistakes. Art is knowing which ones to keep. -Scott Adams, cartoonist (1957)
Old 05-01-2013, 01:05 AM
Grizla Grizla is offline
life saver thank you
Old 08-15-2013, 01:43 PM
jwolford jwolford is offline
Thanks for the solution, I have been fighting with this all morning. Holding down the "n" key and changing my settings did the trick.
Old 08-15-2013, 01:52 PM
YYR123's Avatar
YYR123 YYR123 is offline
U know there really should be a sticky with !!! Or include that in some kind of documentation when people install ProTools
Daniel
For the Love of everything sacrosanct and hallowed, Why hasn't track presets been implemented yet? - George Jetson
For the Love of everything sacrosanct and hallowed, Why hasn't track presets been implemented yet? - George Jefferson
For the Love of everything sacrosanct and hallowed, Why hasn't track presets been implemented yet? - George Clinton
10.3.1 "Could not create new doc because Assertion in.." MarkH Pro Tools Software (Mac) 19 12-26-2014 10:09 AM
Could not create new document because assertion spiker Pro Tools Software (Mac) 1 07-01-2013 02:06 AM
"could not create a new document " paulstapp Getting Started 1 06-19-2013 02:59 PM
PT Could not create a new document… assertion frcjt Pro Tools Software (Mac) 2 02-27-2012 06:29 PM
