Avid Pro Audio Community |
#21
Ok thanks.
Not shure I fully understand the 32 bit float point thing. What benefit would i gain by recording in 32 bit float point when my Mbox 3 Pro converters are limited to 24 bit ? Im thinking its more of a mixing benefit than recording ?
Christian D ♫ http://chrisdee.bandcamp.com/ ⌨ |
#22
32 bit float point is kind of an "invisible" mixer, if you will. It's not handled by the converters, it's a completely internal process. It's nice for a few reasons, but most importantly is how much more headroom the software has. Basically, with 32 bit float processing, you can never clip internally. This gives you infinitely more breathing space in the mix.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
#23
![]() ~peter in oakland |
#24
What Avid should do though to bridge the time until we get a 64-bit version (and I put this up on the ideascale site as well) is to allow third party Rompler and Sample plugins, that support disk streaming, to stream the samples from the new RAM disk Cache in PT 10.
This will allow those plugins to read and write their samples from and to the RAM cache and sort of ditch the memory limitation until they come up with a full 64-bit version of Pro Tools. This will keep the user base happy AND give them time to develop the ultimate 64-bit pro tools version without being harrassed every odd minute. Would be a cool feature ![]() Maybe in version 10.1?
Bortraws |
#25
There is one reason and only one reason PT is not 64bit already it is because they are a Cash Cow. They have milked RTAS & TDM for so long at the cost of our money while every other DAW out there was using VST and going 64bit.
Mean while PT used their major market share to bleed everyone till the bitter end. Now the day is growing near that we will see PT 64bit and RTAS,TDM will be gone and a new standard will be made to take their place at a major cost to us all the while there are other DAW's out there that only lack one thing PT milks all of us with... Market Share. |
#26
#27
Interesting to see how much market share Avid will loose with this strategy. Cubase and Logic has been 64 bit for a long time now, Reason 6 is 64 bit, Reaper is 64 bit. But the new and future shaping PT10 is 32bit...
Hardware: PC, MC Control, MC Mix, FF400, PoCo, UAD-2 Solo & Duo, LA-610 MKII, Adam A7, TLA Ebony A2, Dbx 266XL, Mopho, Remote SL49, Maschine, Kore2, Launchpad. Software: WIN7 x64, PT 9, Live 8, Reason 5, Sound Forge 9, Komplete 6, lots of paid plugins. Youtube | Soundcloud |
#28
It's also about the legacy hardware guys. The drivers for the old hardware are still based on 32 bit programming. All of the other programs that you're mentioning don't have a LARGE user base of hardware owners out there. The post industry alone has a HUGE investment in hardware, and they are not going to have it become obsolete overnight. They've already given us hints of 64 bit because there is a phase out for the legacy hardware (which has been around since 2002 I believe). If you're ticked off now, imagine if NONE of your plugins or hardware would work today, and you couldn't upgrade at all without a substantial outlay of cash. They're trying to find a way to transition EVERYONE to the next level while alienating the fewest number of users. If 64 bit is what you need more than anything else, then switch platforms. If 64 bit Pro Tools is what you need, then you're going to have to be patient.
#29
I don't buy this excuse at all. It makes sense that it's impractical to update RTAS and TDM to 64 bit for whatever reasons. But that's no reason not to include 64 bit support.
Just make an app that runs in 64 bit with the new plugin format, and if you need to run RTAS or TDM plugins you have to run the app in 32 bit mode. Not the best for users but way better than not supporting 64 bit at all. At least users who have all the plugs they need in the new format can run 64 bit. And if digi really wanted to they could create a bridge so the 32 bit plugins ran as an external process and just send the audio back and forth. Which is what all the other 64 bit audio apps have been doing for years. And if they really wanted to have 64 bit support this decade they could have gone with VST and AU instead of creating yet another new proprietary plugin format, since there are a good number of 64 bit plugins already on both PC and mac. Same goes for hardware support of old stuff that can't be updated. Release a 64 bit app but with older hardware you can only run it in 32 bit mode. PT is hardware independent now, no reason to punish people who are running other hardware that has 64 bit drivers. |
#30
"When the next version of Pro Tools comes out and drops RTAS/TDM support, we'll see 64 bit processing across the board."
I'll wait to upgrade until that happens then. "Just make an app that runs in 64 bit with the new plugin format, and if you need to run RTAS or TDM plugins you have to run the app in 32 bit mode." That's what Logic has been doing for a couple years now - you can choose between opening it in 32-bit or 64-bit mode. The 32-bit plugs still run in 64-mode, with a "bridge". An extra step, clicking on a window to open 32-bit plugs is somewhat annoying, but still better than no 64-bit option imho. "Basically, with 32 bit float processing, you can never clip internally. This gives you infinitely more breathing space in the mix." Cubase had this 10 years ago (yes, 10 - a decade).
Macbook Pro 15" 2.66 i7, 8GB RAM / OSX 10.6.8 and 10.7.1 / Pro Tools 9, Producer Factory Pro / Kontakt / EWQLSO Gold Play Edition / Steven Slate Drums / Logic Studio / Apogee Duet |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to reinstall PT10 if PT10.3.2 upgrade failed? | Martin11 | Pro Tools Software (Win) | 12 | 12-09-2012 02:16 PM |
| PT10 HD system can't cope with session created in PT10 (LE) | LizS | Pro Tools 10 Discussion | 19 | 07-27-2012 02:46 PM |
| Bought PT10, do I remove the PT10 demo? | esperanto | Pro Tools Software (Mac) | 2 | 04-18-2012 11:01 AM |
| PT10 help please , does PT10 really work on win 7 (digi support please) | digi003 | Pro Tools Software (Win) | 6 | 02-01-2012 05:36 PM |
| PT10 interop with PT9/8/7 -- Can PT10 force .ptf compatible audio? | jeremiahmoore | Pro Tools Post & Surround | 8 | 10-25-2011 07:55 PM |
