Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Mac)
Old 09-24-2011, 09:28 PM
protools123 protools123 is offline
Default Profire 2626, Project Mix I/O, PT9
What would be the best way to connect my Profire 2626 and Project Mix I/O together. Have the Project Mix as the main, and then adar the profire? How would I go about doing this? Cheers.
Old 09-25-2011, 03:17 AM
The Dougfather The Dougfather is offline
Default Re: Profire 2626, Project Mix I/O, PT9
Use the Project Mix as the interface and then connect the 2626 using ADAT for 8 channels of expansion.
The ProFire 2626 doubles as a standalone 8-channel preamp, 8-channel A/D-D/A converter and digital format converter. In standalone mode, the eight analog inputs route to the first eight ADAT optical output channels. This facilitates use of the line, instrument and mic ins—including the preamps—with other digital gear. Similarly, the first eight ADAT optical input channels feed the eight analog outputs to provide D/A functionality. You can also disable the D/A conversion to allow the analog input channels to route to both the analog and ADAT optical outputs—transforming the ProFire 2626 into a standalone 8-channel mic pre with eight discrete analog outputs plus 8-channel ADAT output. When the second optical port is not used for A/D conversion, the ProFire 2626 can also convert coaxial S/PDIF to optical S/PDIF.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 09-25-2011, 06:56 AM
albee1952 albee1952 is online now
And don't forget to set the Optical as the clock source
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas..............................
www.capricornsoundworks.com
Old 09-25-2011, 11:16 AM
So do I need the pro fire to be connected by firewire as well, or just the project mix?
Old 09-25-2011, 11:35 AM
Just the Project Mix. The 2626 needs only a lightpipe "cable" to the PM optical input.
Old 09-25-2011, 11:57 AM
That's what I figured. 2626 out to project mix in?
PT MP9 & ProFire 2626 Rjones17 Pro Tools M-Powered (Mac) 0 12-04-2012 11:48 AM
Is the Profire 2626 more stable than Profire Lightbridge? (PT8 or snow leopard?) tomv-k Pro Tools M-Powered (Mac) 5 03-09-2012 02:45 PM
Driver Conflict ProFire 2626 and Project Mix doppler58 Pro Tools M-Powered (Mac) 1 10-06-2010 10:54 AM
ProFire Lightbridge / Project Mix IO / Pro Fire 2626 doppler58 Pro Tools M-Powered (Mac) 4 09-02-2010 11:49 AM
If you have a mac and a profire 2626, could you please help? theaero Pro Tools M-Powered (Mac) 5 07-14-2008 01:32 PM
