Old 08-28-2011, 09:25 AM
Firechild Firechild is offline
Default Control 24 Dark scribble displays
I have a problem with some scribble LED´s becoming really dark on my Control 24, some are fine but some are so dark I have to be very close to be able to read them...
I don´t find any LED Contrast settting either...
It started with 2 channels, now maybe 12...
I think this is a common problem but I still haven´t found a solution or a theory what is causing this ?
Today, all Scribble LED´s are very dark, including the "Channel Bar Display" som there seem to be a connection problem.
Does anyone know where to find the right socket to tighten?
I removed the backplate where the power switch is but everything seems fine there.
Is it easy to move the larger backplate where all the audio inputs are ?
HD3 PCIe, HD I/O , HD10.3.10, Mac Pro 6 core , 24 GB RAM , GTX285 , 10.8.5 , UAD-2 Quad Satellite , ATC SCM25A Pro with ADAM Sub 12.
Old 11-02-2011, 04:54 PM
Thedarkcure Thedarkcure is offline
Default Re: Control 24 Dark scribble displays
I have the same problem and I wrote to the Italian service center but I have not replied ...
You are able to solve the problem, if you can it do?
Old 11-03-2011, 12:09 AM
I have contacted two service centers but only one replied and recommended the other ...
So no Solution for me.
Everything else is working fine so I guess I will just live with it...
I removed the backplate and it is very tight inside but all sockets seem fine. Have no clue what is causing this "darkness"...
Old 11-03-2011, 02:30 AM
Audiohitch Audiohitch is offline
I had this problem a couple of years ago. It was a component within the power supply had gone. It would work every now again if I hit the console.
I got a replacement from Digidesign as they acknowledged it was a known problem and sent out a replacement part for me to fix. They do take credit card details incase they don't receive the faulty unit back.
I did take me a good hour or so to fix. If you are a competent person with a little bit of knowledge of electrics then you be okay to replace it yourself.
Old 11-03-2011, 09:45 AM
Almost certainly flaky molex connectors from the supply board to the display boards. I got rid of my Control 24 years ago, but towards the end I used to have to disassemble it every 6 months or so and clean all the molex connectors on the supply board with cramolin or the scribble strips would start disappearing. It's no fun getting inside there; LOTS of screws to take of the bottom and the thing is bulky and heavy as you may have noticed. If you don't know what you're doing you should probably leave it to a pro.
best,
rich
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Control 24 scribble displays flickering? please help primomusic ICON & C|24 7 01-29-2013 08:43 PM
Control 24 scribble displays flickering? please help primomusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-22-2013 02:27 PM
Help!! scribble strip display, dark DesertMoney ICON & C|24 1 11-26-2010 06:37 AM
Control 24 "Scribble Strips" - two displays not working Kevin Mowry ICON & C|24 6 07-26-2008 12:19 AM
scribble strip displays HR instead of track name ggonda ICON & C|24 1 05-06-2008 01:34 AM
