Have Xpand 2 midi track with multiple drum sounds,n midi notes in a single clip.
I then use the event operations split midi notes option.. I choose all notes to split by a new track per pitch... Okay now that I have these all split onto new midi tracks, why ias it that Xpand 2 doesn't follow these tracks? What is the workflow here with this? Do I have to then choose midi channels for each newly created midi track or what? Why is it that PT can just do this for me? ![]() Next I solo a midi track that has been split, but there's no audio if I solo the midi track?? Do I have to also re route audio to the midi track, where's the right workflow here?? Any tips out there?? thanks in advance!
Mac Mac Pro 8 Core|12GB Ram|Snow Leopard OSX 10.6.7 Pc Core i7 950|X58A-UD3R|12gb Corsair Dominator 1600mhz|Win7 64 Hardware: Mbox3|Mytek Stereo192 AD|Mytek Stereo96 DA Akai MPK 88|Novation 61SL MKII |Grace 101|Focusrite Pre Monitor Station|HP4|Faderport|DynAudio Bm5a MK2|Event Tr8|22 GIK Traps|2Ears Software: Pro Tools 9.03|Logic 9|Studio One Pro |
Yes, route each split midi track to that instance of Xpand. To solo a split midi track, you have to also solo the Instrument track as that's the actual audio channel for Xpand.
At least while working on those tracks, it might simplify things to put the XPand Instrument track in solo-defeat so you don't have to shift-select solo it with others everytime. |
It's pretty stereotypical of low-end products like Xpand! where functionality isn't that integrated. Where as products like AIR Strike, FXpansion BFD, Geist support a higher level of self contained functionality. Try setting up a Template.
Aaron Mulqueen - 001 HD Native |
this doesn't have really anything to do with Xpand,fwiw I think Xpand is the best plugin I've played in awhile,and I wish Avid would allow it make it a vsti vs just rtas! it's more or less a problem with PT. Here's what I'm saying take the daw Studio One for example - if I split a a drum track's midi clip to dissolve the parts, it separates the individual midi notes,but the instrument is on all the tracks after the new split.. So I don't have to go reassigning midi channels etc.. great workflow! And then if I want to solo say a kick,and a hat, the instrument is in tact,and I can do this,and the workflow is there.. with Pro Tools ,unless I'm missing something,this workflow is not possible,and slows one down.. I get what your saying about a template,but I have enough skills to play the drums all in one pass,and prefer not to have to play a kick, then record a snare,then record a hat.. slooooow not fun.. I don't own any of those other plugins,and to be honest I shouldn't have to.. I own other plugins like Maschine,BPM,M52,others,and it's the same problem. This isn't a Xpand problem,it's a weak workflow issue for Pro Tools and imo if after 9 versions they don't get i,they never will.. Thanks goodness for other daws.. ![]()
That's integration I really don't think we'll ever see between Pro Tools and AIR Virtual Instruments. Don't get me wrong that sort of functionality is top of my wish list but in reality I don't hold my breath. There are bigger fish to fry.
Xpand!2 has a lot to offer but compared with AIR Strike or FXpansion BFD or Geist that are truly self contained modules, Xpand! is in comparison limited. I guess all you can do is submit your Feature Request at IdeaScale. Good luck.
It isn't that difficult to shift-select the separated midi track and assign them to the Instrument track all at once.
Copied routing isn't a limitation of the VI - it would only take a preference for newly assigned midi tracks to take the routing of the previous track (and perhaps there is one - not in front of PT at the moment). As far as DAWs that "duplicate" a single VI's routing, including audio channel routing, on multiple tracks - that becomes a serious pain to deal with when you have a lot of VIs - say a scoring template. RTAS/PT's approach actually makes more sense in that respect - it's a single destination that can't be confused with dozens of "multipurpose" tracks that happen to look identical, save some time consuming manual color coding (such as with Reaper). |
Confuse with dozens of multipurpose tracks?? Have you actually tried what I'm talking about in Studio One?
It definitely doesn't get confused.. It simply routes the audio correctly to the mixer and midi instruments to the separated midi tracks.. Then in fact you can bounce and be done... whereas PT you have to realtime bounce- slooooow! PT is far behind Studio One in this regard.Workflow hello??? ![]()
I offered you a very quick and simple solution to your question. But if you prefer and use Studio One, why bother even asking about how to do this in ProTools?
Fwiw, I'm not talking about the app getting confused - I'm talking about visual management of hundreds of tracks and many VIs/external slaves/VEPro instances, for which PT is fast and efficient for my workflow - ymmv of course. Yes, I've tried Studio One - some nice features for simpler projects, but even a function like auto-output assignment doesn't make up for other significant workflow advantages in PT for me. If it works for you, then by all means, just use Studio One. |
Write within the drum program.
But then he can't complain about Pro Tools
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Select/Split notes not working in PTLE7 | Mcgrathx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-23-2013 06:32 PM |
MIDI Select/Split Notes - Assertion in PT8 | gonzolagonda | Pro Tools TDM Systems (Mac) | 3 | 08-18-2009 05:34 AM |
7.4 Crash on Select/Split Notes | paulmellors | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-21-2008 08:40 AM |
Midi - Split Notes in Pro Tools | bassbuddy | MIDI | 2 | 09-18-2006 04:46 PM |
I have alot of "low end pop" a split second before playing single higher notes on gtr | mikerica101996 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-18-2000 08:01 PM |
