Pro Tools throwing cpu error messages
I am running the latest version of pro tools 9 on a 3.06 ghz core 2 dou Imac with 8 gigs of ram. Even in a session that has one midi track (going out to a yamaha motof), an aux in, and a master fader, I will get an error message saying I am out of cpu power.I have the buffer set to 512. Any help would be great. Thanks.
Re: Pro Tools throwing cpu error messages
There are probably more than a few tweaks you should do to get things hunky-dory.. however, go set your processors to one less than your maximum and at 99%. (SETUP/PLAYBACK ENGINE)
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
The max value pro tools will let me set is 90%. And thats where i have it now.
Thanks for responding so quickly :) |
Make sure you have your screens saver set to off and no hot corners enabled for any expose, spaces, etc. Shutdown then start up and launch pro tools without any other apps running like mail or safari etc. I found that any of these things which Avid says should be off can cause dae errors CPU etc. It helps to know exactly which errors you are getting -6085 etc. Also bluetooth and wifi should be off. Once it seems things are good then you can see if you can sneak some of these things on, but I found the screen saver was putting something in ram that really messed with Pro Tools and I would get a 6085 error and have to reboot. Pro tools 8 was not as touchy as Pro Tools 9 is for me as far as things like spaces and screensavers etc.
What do you have setup as an audio drive?
What interface are you using?
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
Here you go Follwo this link it has tons of information it is all there
also, there is a tutorial at www.Lynda.com addressign this issue http://duc.avid.com/showthread.php?t=54888 Cheers Itzhak
Everyday Is A Good Day http://www.bandmix.com/itzhak/ My Music www.itzhakyaron.com |
I am using a 7200 rpm usb drive for my external drive, and a saffire pro 40 for my interface.
did you see if you get the same errors playing back a session with the built in mac soundcard, to rule out a problem with the saffire?
Pro tools gives me error messages | Protoolsdub | Pro Tools M-Powered (Win) | 5 | 12-31-2012 01:03 PM |
Pro Tools keeps throwing me ERRORS | ReynaldoPena | Pro Tools SE and Essential (Win) | 0 | 10-22-2011 07:41 AM |
Many different error messages, Pro Tools aborting or unable to click messages off | riffmachine | Pro Tools M-Powered (Win) | 5 | 10-05-2010 04:15 AM |
pro tools issues & error messages | mike8338 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-31-2009 08:39 PM |
Pro Tools M Powered Error Messages | jomeo69 | Pro Tools M-Powered (Mac) | 1 | 01-30-2007 08:54 AM |
