Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Go Back   Avid Pro Audio Community > Legacy Products > Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac)
Old 06-13-2011, 07:47 PM
saltydeath saltydeath is offline
Default External mic with pro tools 8 LE?
I just set up pro tools 8 le. I have an external mic and an m-audio transit usb. Can I hook up the mic to get input through this and record into pro tools? Or is there something where m-audio isn't compatible with le?
Old 06-13-2011, 08:06 PM
Dism Dism is offline
Default Re: External mic with pro tools 8 LE?
only if the mic is external enough
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 06-14-2011, 06:48 AM
Pro Tools LE will only work with a compatible Digidesign or Avid interface(Mbox, 002 or 003). Pro Tools M-Powered will likely work with the M-Audio Transit with the mic plugged into the Transit. Neither software will recognize a USB mic(you didn't give much detail).
Gigabyte GA-EX58A-UD3R, Intel i7 950, 12 gig Corsair DDR3, PNY GeForce 210, Focusrite ISA428, Octopre Mk II Dynamic, Lucid GenX192, DIGI003 running PT10HD, Vintech and Five Fish preamps..............................
http://www.myspace.com/cswstudio
www.capricornsoundworks.com
The cool thing about digital is; there's 4 ways to do everything. The bad thing about digital is; there's 4 ways to...........
Old 06-14-2011, 10:40 AM
Sorry, let me explain. I have a Shure SM-58 mic connected to an M-Audio transit which is run into the computer. What I was wondering is if this transit will work with pro tools 8 le, or if there's some incompatibility between LE and M-audio in pro tools. I only have an mbox2 mini which doesn't provide for input, so I'm confused about how to get audio input to start recording into pro tools.
Old 06-14-2011, 11:52 AM
MBox 2 Mini most certainly does have a mic input on the back.
M-Audio hardware is not compatible with Pro Tools LE. Only M-Powered and Pro Tools 9.
D
Old 06-14-2011, 11:55 AM
Did you mean an Mbox MICRO? The Mini does have 2 inputs(one line/DI and one XLR). The M-Audio box is not going to work at all. Your options are either buy M-Powered software(which should work with the Transit) or buy a Digidesign/Avid interface. Lots of used Mbox 2 models floating around craigslist or evilbay. Often without software(which you have) so the price gets even better. Avoid the original(pale blue) Mbox with the Focusrite preamps as it is no longer a supported product(although it will work with PT8.0.1, but not newer versions).
Old 06-14-2011, 02:10 PM
The one I have is the micro, not the mini, sorry. I'm looking at it now and I'm pretty sure it's only audio out, right? It doesn't make sense that it only allows you to listen to audio coming out but has no line in. So if I have to upgrade to an Mbox mini do I need to buy a new license, or will it work with the one I already have?
Old 06-14-2011, 02:45 PM
The Dougfather The Dougfather is offline
Default
Pro Toole LE works with all digi interfaces OS permitting so just plug in a mini and go.
Sent from my iPod touch using Tapatalk
Powermac Dual G5 2.5GHz, Macbook Pro 2.4GHz, Pro Tools 9/10, MOTU 828mk3, Audient ASP008, Presonus Digimax FS, TC Konnekt 24D
iCON Recording & Audio
best external HDD for pro tools musicery Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) 22 09-26-2009 07:36 PM
External HDD for Pro Tools LE The President Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 4 06-25-2008 04:47 AM
Pro Tools and External Maxtor IRADJ Pro Tools M-Powered (Win) 1 02-14-2006 10:22 AM
What is the BEST external H.D. for Pro Tools LE GorillaK Storage Subsystems 3 06-09-2005 06:19 PM
External HD for Pro Tools LE? EricLiebman Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) 4 05-30-2000 06:29 PM
