Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Go Back   Avid Pro Audio Community > Legacy Products > Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac)
Old 06-13-2011, 03:33 PM
uptowners2010 uptowners2010 is offline
Default Exporting Audio Files for mixing
ok i use pro tools 8 le and i use virtual instruments. now i know about recording audio and that you have to record it at the highest level before distortion, but im using virtual instruments, so if i wanted to export strings to mix in another program or a mixing engineer, would i have to set the level to the highest before it hits distortion and then export it,,or it wouldnt matter because it was recorded internally via virtual instrument. i guess the question im really asking is, how do i prepare a song for mixing later on. like levels of each track and such ?
Old 06-13-2011, 03:54 PM
Craig F's Avatar
Craig F Craig F is offline
Default Re: Exporting Audio Files for mixing
you are fundamentally wrong about recording each element as hot as possible.
end product is much better if each element has 12 to 24 dB of average headroom.
so print each VI so the average level is the area were the meter changes from green to yellow
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Old 06-13-2011, 05:56 PM
Top Jimmy's Avatar
Top Jimmy Top Jimmy is online now
Ditto.
James Cadwallader
"Men occasionally stumble over the truth, but most of them pick themselves up and hurry off as if nothing had happened."
-Winston Churchill
Exporting Audio Files gz131 Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 2 04-20-2009 12:26 PM
Exporting PT audio files to Logic w/o OMF, how? sirgant Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) 1 11-11-2007 03:56 PM
Exporting Regions as Audio Files HiRaX Pro Tools TDM Systems (Mac) 6 11-28-2005 06:35 PM
Exporting Logic audio files.... Eric9volt Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) 2 11-11-2001 04:00 PM
Exporting/importing audio files between PT le > Logic > PT le ? P_J Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) 2 10-22-2000 11:15 PM
