Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Win)
Old 06-03-2011, 04:11 AM
hotsihombing hotsihombing is offline
Default pro tools 9 and motu 2408mk3
Hello,
i want to know if anyone in DUC ever use and work with 2 Motu 2408 MK3 + protools 9 (OS Windows 7 64 bit)
or
2 m-audio delta 1010 + protools 9 (OS Windows 7 64 bit)
please let me know
thank you for the answer
Old 06-03-2011, 06:21 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: pro tools 9 and motu 2408mk3
2 Delta 1010lt's was possible with M-Powered 7.x, but I don't think so with PT 9.x. At least from what I've seen here in the forums with people who have tried, no one's been successful.
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS Sierra Version 10.13.1
Pro Tools HD 2018.3.0
Old 06-03-2011, 07:18 PM
glennpittaway glennpittaway is offline
Smile Re: pro tools 9 and motu 2408mk3
Originally Posted by hotsihombing View Post
Hello,
I have precisely this set-up. I've been using it for around 5 months now, and after the initial hiccups (I moved from a Mac G5 and Digital Performer), everything seems to work nicely. What do you want to know?
Old 06-04-2011, 10:00 AM
Varela Varela is offline
I've got the old 2408, (not mk3) but I did'nt test yet. I will install it next week and maybe have some to tell you.
Regards
Old 06-04-2011, 10:15 AM
to glennpittaway :
Can you record simultaneously using 2 unit of MOTU 2408 MK3 (all 16 analog input only) ???
if you can record all 16 analog input, please let me know how you connect 2 MOTU 2408 MK3, both of your MOTU 2408 MK3 connected to PCIX-424 card/PCIe-424 card inside your PC that running Windows 7 x64 ??? or only one of your MOTU 2408 MK3 that connected to PCIX-424 card/PCIe-424 card inside your PC and then you use ADAT cable to connect the 2nd MOTU 2408 MK3) ???
Old 06-04-2011, 11:11 AM
to glennpittaway :
I haven't recorded simultaneously on all 16 analog inputs, but I have mixed using all 16 analog outs - it worked with no problems.
Both interfaces are connected to the PCIX-424 in the PC (the card has four slots, so no reason not to connect them that way). I use all analog connections for the interfaces (input and output), and have disabled ADAT etc.. I have a Presonus 8 channel pre filling 8 inputs on one interface. On the other I have 2 UA 6176s, an API 512c, and an Alesis keyboard (stereo). I currently have one spare input, the final pair of inputs take the output from my 2-BUS LT summing amp.
Hope that helps.
Old 06-04-2011, 02:26 PM
thank you for your answers,
any problem when installing MOTU 2408 MK3 with windows 7 x64 + pro tools 9 ??
Old 06-04-2011, 03:24 PM
No problems that I recall. For a while I thought I had a problem with the interfaces - they would seemingly randomly revert to 44.1K. I thought it was something to do with the MOTU drivers, but then I figured it might be Windows doing it, which proved to be the case - I've seen this referred to elsewhere in this forum.
Other than that, relatively smooth sailing.
Old 04-20-2012, 01:35 PM
bennym bennym is offline
Any issues with Latency ? Can you use LOW LATENCY MONITORING w/ the MOTU 2408mk3 ?
Old 04-23-2012, 06:27 PM
smpkeys smpkeys is offline
can any of you guys using this track a band at 64 or 32 samples successfully without getting the 6101 CPU errors?
2010 Mac Pro, 3.46 GHz 6 Core Xeon,32 GB RAM, OSX 10.9.5, PT 12.4, RME Fireface UFX, Command 8, Mytek 8x192, SSD evo on System,Audio&Samples on spinner drives WD SATA 64mb Cache
PT9 and Motu 2408Mk3? derF Pro Tools Software (Mac) 0 12-09-2011 03:28 AM
Pro Tools 9 and 2408mk3 hardware ChicoB Pro Tools Software (Mac) 4 03-28-2011 12:07 AM
Pro Tools 9 with old (c. 2003) MOTU 2408mk3 RadioMoo Pro Tools Software (Win) 5 12-17-2010 06:11 AM
HD 96 I/O vs MOTU 2408mk3 fmckinnon Pro Tools TDM Systems (Mac) 5 10-04-2002 08:46 AM
001 user upgrade question - HD 96 vs MOTU 2408mk3 fmckinnon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-30-2002 10:46 PM
