Old 05-30-2011, 05:40 PM
PBGas PBGas is offline
Default GUI not able to select ERXP amps
Hi Gents,
Had this problem previously with the amps not displaying in the Pro Tools 9 GUI. Now it's happening again and not fixing with the usual methods of trashing the files in the plug-ins folder and re-loading them to the computer.
I can't select any of the ERXP models in the GUI. The box itself works fine in that sense.
This is really getting frustrating and I'm not sure at all what to do.
I did try and re-install the 11R drivers and that did nothing to help.
Kind of pointless for me to keep this box when this keeps happening. I guess I am just a bit frustrated at this point.
Not sure where to go or what to do.
I'm using an iMac i7 with 10.6.7 and 16GB RAM and Pro Tools 9.03
Any help is appreciated.
Old 05-30-2011, 06:57 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: GUI not able to select ERXP amps
From this comment I assume you've successfully updated 11R Firmware to v2.01
Have you re-run the Software updater that came with the ERXP after re-installing drivers?
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 05-31-2011, 06:15 AM
Thx for the reply.
Will try when I get home tonight. Pretty much sure that I did this again.
Just really frustrating because it was working fine previously.
Old 05-31-2011, 04:35 PM
Checked for updates. All was previously updated.
GUI still not working properly when in Pro Tools.
I'm stuck.
Old 05-31-2011, 04:42 PM
Benoni's Avatar
Benoni Benoni is offline
I'm stuck.
Did you re run the ERXP, just the first part, you do not need to update the firmware.
The first part installs the GUI files needed for the ERXP.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 06-01-2011, 09:10 AM
Yup. We did this last time. But even before that....I was able to select the amps. For some reason, they are gone from the GUI...even after the re-install. For example....on the 11R Bogner Red, it shows a Soldano model on the GUI. I can't access it properly on the GUI and as soon as I touch a setting on the screen, it changes a whole bunch of other settings.
The unit itself works just fine. I just was hoping that I could use the GUI...but alas....looks like it'll never work for me. I'm wondering if I need to do a complete re-install of Pro Tools for this to work properly?
I'm seriously thinking that perhaps I'll move to a software solution - Amplitube or Overloud TH2 for the GUI end of things.
again, really frustrated.
Select in Region bin won't select region in edit window? innerbooty Pro Tools TDM Systems (Mac) 3 03-24-2013 11:04 AM
Mbox 3 Pre amps vs. External Pre amps? evanbgrove 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-10-2011 05:21 AM
Erxp mia? ac30fan Eleven Rack 3 11-08-2011 05:37 PM
What if new 11R does not come with ERXP? dperreten Eleven Rack 20 10-20-2011 03:36 PM
Mbox 2 pro... Pre Amps (vs) 003 Pre... Amps Norm Mix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-24-2009 02:37 AM
