Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Win)
Old 04-18-2011, 03:20 PM
homestudiopro21 homestudiopro21 is offline
Unhappy PACEAP Driver Not Installing
hey guys im new to the forum but have been using protools for the last 5 years and havent had many problems until recently.
***Note*** - although this is a PACE-AP problem i didnt know anywhere else to ask advice from.
anway.......... aftewr a few days of receiving my iLok 2 and tying to install Protools 9 which installs fine, but i have found that when trying to update the PACE drivers using the Latest Driver installer the installer splash hasnt actually poped up to allow me to install the new driver.
It just stays at the "License suport wizard loading/install Microsoft DLLs" box
Now this might just install the new drivers without going through the installtion "pop up", i dont really know tbh
so i wondering if anyone had any advice or has had this problem previously and has a solution(s) to this particular problem?
Old 04-18-2011, 06:21 PM
brad383music's Avatar
brad383music brad383music is offline
Default
Your not using firefox 4 web browser by any chance area you?
Win 7, PT 9, 11 rack, superior drummer 2.2, Gibson guitars, yamaha bass, Dimebag washburn
Eleven Rack + ERXP
Pro Tools 9
Windows 7
Gibson Guitars
Washburn Guitars
Michael Kelly Guitars
Yamaha Bass
Roland TD30K
EZ Drummer 2
Superior Drummer 2.2
Old 04-18-2011, 08:26 PM
Default Re: PACEAP Driver Not Installing
yes i am atm, ive uninstalled IE8 becuase a few people have been saying that that can cause problems with PT.
DO u think that Firefox is conflicting with the PACE-AP driver?
Old 04-18-2011, 10:24 PM
Default
Most definatly. I had exactly the same issue. Revert back to FF 3.6 and your problem will be solved. Make sure you completly uninstall FF4.
Eleven Rack + ERXP
Pro Tools 9
Windows 7
Gibson Guitars
Washburn Guitars
Yamaha Bass
Roland TD30K
EZ Drummer 2
Old 04-21-2011, 11:36 AM
right ive tried this and still its not working..........
opening the Task manager with the driver install program running and it seems to be crashing durring the installtion
any ideas to stop it from crashing?
Old 04-21-2011, 11:50 AM
mykhal c's Avatar
mykhal c mykhal c is offline
exactly what are you tryin' to install?? PT drivers? Pace drivers? iLok drivers? i'm confused as to what step you're on...
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 04-21-2011, 12:59 PM
ok.........
i have installed the Ilok client helper + the PACE driver that it comes with....
as expected I receive the PACE error 3 box after installing PT and rebooting the machine.
with that in mind I have been trying to install the current up to date drivers, but the driver installation license wizard screen has been crashing before I actually get a chance to install the new driver.
Old 04-21-2011, 01:09 PM
mykhal c's Avatar
ok...go to control panel then programs and tell us what version of the Pace drivers you have installed. if you see ONLY 5.8 drivers then that is your problem. PT installs and looks for Pace 5.9.x drivers. if this is failin' then the order in which you've done things might be the problem.
Old 04-21-2011, 01:21 PM
ok....... well ive got 5.9.1 on my computer
should i install PT first then install the Ilok drivers?
Old 04-21-2011, 01:33 PM
mykhal c's Avatar
make sure you have installed the PT drivers first. then reboot as instructed...leave device turned off...install PT9...reboot...turn on device as you reboot...check device manager to ensure device is installed and recognized...if it looks good then start PT. hope that helps...
DigiHFS not installing (HFS+ Driver) corthreat Pro Tools Software (Win) 0 08-23-2012 01:12 PM
installing M-Audio Driver Sir Les Pro Tools M-Powered (Win) 1 06-06-2007 01:34 AM
Driver problem when installing PT7? bcu11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-25-2005 10:30 PM
Installing Motor Mix driver fr LE 6.4 CD:where to? Tubthumper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-08-2004 05:03 PM
help installing driver on macg4!!!!!!!!! KemikAL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-27-2002 10:26 PM
