Old 04-10-2011, 08:28 AM
ppiispa ppiispa is offline
Default Occasional headphone out problems with Mbox 3 Pro
I'm encountering occasional problems with headphone outs on a quite new Mbox 3 Pro. Most of the time both outputs work just fine, but sometimes one of them only puts out static noise. Problem disappears when turning the Mbox off and on again. Problem also seems to randomly affect both headphone outs (but only one at a time), so it seems that headphone amps are ok. Has anyone else encountered similar problems and do you have any idea if this is a hardware or software issue (just wondering if I should return the product and get a new one as long I still can)?
EDIT: Forgot to mention that I'm using the latest drivers, Pro Tools LE 8.0.5 and Macbook Pro 13 (early 2011).
Thanks in advance!
Old 04-10-2011, 05:55 PM
tuyun tuyun is offline
Default Re: Occasional headphone out problems with Mbox 3 Pro
Me too!!!
Old 04-11-2011, 05:56 PM
FICO FICO is offline
I have the same problem. But sometimes I have no noise, the outs are dead. When I turn off and on again the Mbox, the problem is solved. Any suggestion?
Old 04-19-2011, 07:45 AM
bedfordstop bedfordstop is offline
I was having this issue as well, it was really bizarre. I went in and trashed all the prefs, and i also changed the headphone output routing so that they were not both accessing 'stereo mix 1' and the problem seems to have gone away for the moment, i am not sure which of those actions helped. Still, this software and / or hardware has been super glitchy for me so far. i kind of want to do a fresh reinstall of my OS and PT 9 at some point to see if i can shake the gremlins out.
Old 04-19-2011, 01:18 PM
DigiTechSupt's Avatar
We've been able to repro this issue and have it in the queue for a fix.
Thanks for the reports.
Avid Audio Tech Support
Support FAQ
Old 04-19-2011, 01:39 PM
mizieg mizieg is offline
I also have this problem - looking forward for a fix...
M -Ziegler
Copenhagen Denmark
| iMac 27" 3.2 Ghz Core i3 | 8 GB Ram | Pro Tools Mbox Pro (3) | Lacie d2 Disk Quadra v2.1 1 TB FW | Pro Tools 10.3.3 (always newest update) | MPT2 | OS X 10.8.4 |
Old 04-23-2011, 01:27 AM
Gabrielzen Gabrielzen is offline
Same here! I'm looking forward for a fix too! please!
Old 04-23-2011, 07:40 AM
aenigma aenigma is offline
I'm also having an issue with my headphones.
I've had the Mbox for only a few days, and I would say over half of the time I have no sound coming out of my headphones for tracking, but I can listen back to what I record. Other times I can't get any sound at all. This is pretty frustrating, especially since this thing isn't even a week old.
Closing ProTools and restarting the Mbox has helped, but there have been several occasions I have had to restart it more than once to get everything going.
Old 04-23-2011, 12:17 PM
For a start it would be nice to hear an answer to this basic question:
IS A SOFTWARE PROBLEM OR A HARDWARE PROBLEM?
Thanx!
Old 04-24-2011, 05:21 AM
I might be wrong, but my guess is it's hardware. I've used other Mboxs with ProTools 8 and have never seen this problem.
Eleven Rack headphone port versus MBOX and other interface headphone ports World Spirit Eleven Rack 3 02-12-2012 11:34 PM
002 console headphone problems mote45 Tips & Tricks 2 01-03-2006 10:15 AM
Having Headphone Monitoring Problems Cannibal80 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-26-2005 02:40 PM
mbox - occasional playback distortion bjkiwi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-05-2005 12:19 AM
headphone monitoring problems.. tim carter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-11-2003 03:52 PM
