Old 04-07-2011, 10:40 AM
cdmstudios cdmstudios is offline
Default ASIO Drivers for Pro Tools 9 in win7 64bit DO NOT WORK
Hi -
I just "upgraded" my whole system to win7 64bit assuming (unfortunately) that since 8.0.4, the whole 64bit ASIO driver issues had been resolved. Well, at least I was able to use them before. Now, they simply do not work in 3rd party software. Using Sony Vegas Pro, or Sound Forge, or any other DAW, the cursor does not move during playback and there is no response in the meters. In other words, it's unuseable.
Is this a known issue and is it being worked on?
Old 04-07-2011, 11:08 AM
daeron80 daeron80 is offline
Default Re: ASIO Drivers for Pro Tools 9 in win7 64bit DO NOT WORK
There are lots of people using other DAWs with Avid hardware on Win7x64. Must be a different problem. I assume you've gone through all the optimizations and are running as Admin?
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 04-07-2011, 12:32 PM
I'd love to hear from someone who is using one of Sony's products in ASIO mode in win7 64bit with Pro Tools 9 installed. I have heard from several sources that this is a known issue and would love to know if it's being worked on.
I did all the optimizations.
Old 04-07-2011, 04:49 PM
Bill Denton Bill Denton is offline
Maybe I'm missing something, but since it is Sony products that aren't working, don't you think a Sony forum might be a more appropriate place for these questions?
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 04-07-2011, 07:40 PM
George Ware George Ware is offline
PT ASIO stopped working in Sony apps with 8.04 and up!
Acid 7, Vegas 9 & 10, Sound Forge 9 & 10.
Now I run PT 8.03 on one system with Sony and other apps and PT 9.02 on another.
George Ware
Old 04-07-2011, 07:48 PM
Top Jimmy's Avatar
It's not just PT 9 on Win7/64. http://duc.avid.com/showthread.php?t=296620
I forgot about Vegas and Sound Forge on my XP machine. I tried them both with the ASIO 8.0.5 Mbox 2 driver and they are dead in the water along with Reaper and Ableton Live.
I don't know if this has anything to do with it, but the issue appears to be with any program that uses both the inputs and outputs via ASIO. I have tried VIs and Reason Adapted and they all use the ASIO driver just fine. The common theme with those being that they don't use the inputs.
James Cadwallader
Old 04-07-2011, 08:50 PM
TOM@METRO's Avatar
This is odd, but it is the way it is. All of our Sony applications distort audio and experience a total GUI failure thru the Avid drivers. We use an "EchoAudio Layla" for all the Sony Apps. And we leave the Avid interface for Avid only.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 04-08-2011, 06:00 AM
Reaper works brilliantly with 002R on my Win7x64 machine. As do the few stand-alone VIs I have. I can also use it for Skype, both in- and outputs.
Sony is just like that. Remember the days of DAT machines, when all brands could play each other's tapes except Sony?
David J. Finnamore
Old 04-08-2011, 07:30 AM
I think saying "Sony is just like that" isn't the right response. It's clearly a clocking problem in the driver and needs to be addressed. There are a lot of us who share the Digi hardware with both Pro Tools and 3rd party apps and you would think Avid would want to know their driver works with all apps, not just one or two 3rd party ones.
I'm most interested in this thread reaching the Avid Tech folks so they know there is an actual reproducable problem
Old 04-08-2011, 07:37 AM
TOM@METRO's Avatar
+1
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
MBox2 Mini: ASIO Troubles with Win7 64bit!! dRead Windows 8 04-04-2011 06:13 AM
003rack+win7-64bit PC+digi asio driver = midi input (5pin) problem! Slaido 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-22-2011 06:32 AM
Installing Mbox2 Win7 64bit drivers WITHOUT Protools 8 - Have you done this? :-) grasta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 02-25-2011 07:23 PM
Most up to date ASIO drivers for Win7? session_8 Pro Tools 9 1 11-08-2010 10:09 AM
Standalone ASIO drivers for Win7 x64 kenzo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-21-2009 07:57 AM
