Pro Tools 9 and Zoom H4N?
I read on the AirUsersBlog that someone was able to make this work, and i am having absolutely no luck with it. i have Asio4All V2, and PT9 runs fine by itself, or doing any kind of midi, work but When i connect my H4N after the load windows it says "audio device is being used by another program pro tools must close out", anyone having any luck with this? I love my h4n and i have a couple bigger PT8 rigs at home, i didn't want to have to buy another small interface for the laptop. so hopefully this is fixable.
Re: Pro Tools 9 and Zoom H4N?
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
yup sure have, it works ok with record from propellerheads, but not with pro tools. |
Did you manage to get your H4N to interface with protools 9? I just bought protools 9 but haven't received it just yet and am about to head overseas. I'm definitely taking my H4N but would like to avoid taking my M-AudioMobilePre as well. Also - does anyone have any knowledge of performance comparisons between these two interfaces. Thanks. |
nope, tried all new drivers from zoom, tried to update asio, all no go.
I have a H2 and it also suffers the same issue with the ASIO driver. However it does work with the ASIO4ALL driver. If you make active/select the Zoom H Series Audio in the ASIO4ALL control panel (the icons to the left of the device), you'll get I/O to/from the device. I believe both units use the same drivers, so this may apply to the H4N. One issue is -9128 errors, but that may be just a function of horsepower or buffer settings. I still don't get the ASIO buffer setting versus the the PT Playback Engine hardware buffer - they can be different. In the ASIO4ALL control panel, I have the computer output active, the computer input idle, the Zoom H Series Audio input active and the Zoom output idle. I get the audio input from the Zoom and monitor through the computer onboard audio out. Watch out for feed back loops if everything is active.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
sweet it works, that explains why it told me the h4n asio engine was being used by soemthing else. however while recording i do get clicks every so often, but maybe that's cause it is on 48k maybe if i record at 44.1k when using it that will stop. thanks for your help
So I have tried this and it is not working is there maybe something I was missing? Possibly a better way of describing what you did? |
Yes, I have the most up to date zoom drivers and I do start it in interface mode before I turn on PT9.
Need help on ZOOM TOOLS ! | stan_tnguyen | Windows | 1 | 02-08-2013 03:46 PM |
Zoom for Pro Tools 10 | rwk | Windows | 3 | 01-11-2013 06:12 PM |
Lost my Zoom & Zoom preset buttons | nwrstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-07-2012 07:28 PM |
Zoom R24 with Pro Tools 9 | drumstyx08 | macOS | 1 | 12-26-2010 08:15 PM |
Zoom Toggle don't remember horizontal zoom | Riccardo Corbari | Pro Tools TDM Systems (Mac) | 0 | 01-31-2006 05:30 AM |
