Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Mac)
Old 03-27-2011, 06:54 PM
IceLitch IceLitch is offline
Default "Segmentation Fault" "Main Thread" Error
I get an Alert
"Segmentation fault" in thread "MainThread", at address 0x0
I get this every time I try to open the "Session" window, thus, I am not able to open the Session window as Protools crashes after the Alert message.
I am running 9.0.2 on a Intel Mac quad core running Mac OS 10.6.6.
I use a Motu PCI-424e card as the Audio interface with Motu 2408 Mark3's.
Please advise and thanks.
Old 03-29-2011, 12:32 PM
Dode Dode is offline
Default Re: "Segmentation Fault" "Main Thread" Error
Got the same message when quitting Pro tools since 9.02, and then i'm unable to launch it again, until i clear all prefs (Pro Tools and OS X, Audio and MIDI) and reboot. Then i can launch PT one time, but here we go again when quitting it.
Really annoying...
OS X.6.6 with a Digi003R (Complete Production Toolkit 2).
Bye.
Dorian DARCOURT
SoundDesigners.Org, french sound addicts community's founder
Surround Library, Your Surround Sound Effects Source
Old 05-20-2011, 10:29 AM
captainhook79 captainhook79 is offline
I'm getting the same error message, only when I open a session in PT 9, my screen immediately freaks out and begins jumping back and forth from one place in the song to another frantically, like a strobe light. When I close the session and exit PT, it gives me the "segmentation fault" "main thread" error at address....
Does anybody know anything about this or is experiencing the same thing?
I'm clueless at this point.
I can't even work on any session in PT right now.
Mac Pro quad core 2.66
OSX 10.6.7
PT 9.0.2
Old 05-21-2011, 08:56 PM
Carl Lie Carl Lie is offline
Have you tried repairing permissions on you main drive?
Carl
PT 2018.1 HDX OMNI+HDX8x16 -Mac Pro 12 Cores 48 GB RAM OS 10.12.5 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL-GML -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 06-07-2011, 07:18 PM
The reason I "was" getting this message was because I was using two 24 channel Audio interfaces (which are not made by Avid). Protools 9 only supports 32 channels of I/O so PT was freaking out with the extra 16 in/outs present on my second audio interface.
Upon turning off my second 24 channel audio interface, Protools now works perfectly fine. I only get 24 i/o, but thats enough for me for now.
Most Multichannel Audio Interfaces from Avid are 16 i/o or a multiple that so it makes sense why a (second) third party manufacturer's 24 channel Audio interface could cause a problem when PT only can use 32.
Old 08-11-2011, 11:35 AM
jwolford jwolford is offline
IceLitch's poste helped me out.
This error has been periodically kicking my butt for weeks. I could not figure it out.
I move a lot of sessions between locations, and after reading his post, I created a fresh session and deleted all unneeded i/o. After doing this, the session that was crashing 5 minutes ago is now launching.
As a side note, whenever I see this error is when I attempt to regenerate fades, and I usually have Soundminer set up as a rewire insert.
Just sharing my experience.
OS 10.6.8
PT 9.0.3
Quad Core Intel Xeon Mac Pro w/ 8GB RAM.
Old 08-12-2011, 12:14 PM
This kicked my butt again last night. Tried what worked for me earlier in the day, no luck.
I came in today, and launched the same session, and it launched without issue.
It may be worth noting that I am using optical out from the mac for PT audio, and also running Snapper, and occasionally Audiofinsder. Soundminer is connected to PT via rewire.
But the issue, for me anyways, always happens while regenerating fades.
Problem Ask: "segmentation fault main thread address 0x0" GodwinLee Pro Tools Software (Mac) 0 11-14-2013 08:54 PM
"segmentation fault" in thread "Main Thread" , at adress 0x0 melvindesk Tips & Tricks 0 06-13-2012 06:17 PM
segmentation fault in thread "main thread",at address 0x0 when import session data cheney5 Post - Surround - Video 2 05-24-2012 04:00 AM
"Segmentation Fault" in thread"Main Thread" at address 0x0 refuu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-13-2011 05:18 AM
"Segmentation fault" in thread "MainThread", at address 0x0 digidub Post - Surround - Video 5 09-21-2010 01:09 PM
