Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Go Back   Avid Pro Audio Community > Post & Surround > Pro Tools Post & Surround
Old 03-20-2011, 10:51 AM
Danny Caccavo Danny Caccavo is offline
Default Workaround for "Bounce to QT" Problem in 9.0.2
Hi folks - just wanted to throw out a pre-emptive post on what may be the only bug *introduced* in 9.0.2.
Attempting to Bounce to QuickTime Movie results in Assertion.
This happens if you have a 5.1 output path. What you can do to get around this is the following -
Do a "bounce to disk" to a stereo output (or stereo part of 5.1 path). You don't have to complete the bounce, you can abort it with command-period, but the goal is to set the bounce to disk default to stereo.
Now do the "Bounce to Quicktime" and it will work.
This has been reported to Avid already.
-Danny
Old 03-21-2011, 04:11 PM
DAPG DAPG is offline
Default Re: Workaround for "Bounce to QT" Problem in 9.0.2
Thanks Danny!
The DUC is such a great resource!!!
I learn a tremendous amount from all of you and I can't thank all of you enough.
Roy Machado
Dallas Audio Post Group
Old 03-21-2011, 11:07 PM
Dingo90 Dingo90 is offline
thanks for the heads up.
Old 03-28-2011, 06:40 AM
houser houser is offline
Just bumped into this one.
Early info allways crucial and much appreciated!
best
Janne A.
Old 03-28-2011, 10:34 AM
DigiTechSupt's Avatar
We're aware of the problem (usually caused by having a path selected greater than stereo for the output) and have it in the queue for a fix.
Avid Audio Tech Support
Support FAQ
Pro Tools 11 FAQ
Old 03-29-2011, 04:27 PM
minister's Avatar
minister minister is offline
This happens in 8.1.1 (OS 10.6.6) as well.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
"Groupable markers would be epochal!"
-Starcrash
Old 04-19-2011, 04:34 AM
themixfarm themixfarm is offline
Protools 8.1.1. MacPro 2 x 2.4, 6GB, MacOsX 10.6.6. Same Problem.
Thanks for the tip!
Old 06-14-2011, 02:17 PM
Old Man Old Man is offline
Just discovered this bug. Thanks for pointing out the fix. AVID seems to take 2 steps forward and one step back every time there's an update.
On a separate note, if anyone from Digi is listening . . . I would love for Bounce To Quicktime to remember the last video frame size you used also. Seems like it always defaults to 720x486. Bounce to QT should remember all of your last settings. When bouncing to quicktime over and over again like we sometimes do, it's annoying to have to go in and change your frame size ever single time. It remembers every other setting, why not that one?
Tim
Old 06-14-2011, 02:36 PM
Brent_Sydney Brent_Sydney is offline
+2
Kind Regards,
Brent Heber
Sumsound Mixing Theatre
BLOG: www.protoolsprofessional.com (FREE VIDEO TUTORIALS FOR ICON AND HD!)
Old 06-14-2011, 03:07 PM
You should post requests like this to the Ideascale forum:
http://protools.ideascale.com/
Support FAQ
Pro Tools 11 FAQ
HTML code is On
Problem after upgrading to 10.1.2: "Bounce handler could not keep up" Erik318 Pro Tools 10 Discussion 10 05-12-2012 03:50 AM
hardware buttons for "preview", "capture" and "punch" evs Pro Tools Post & Surround 1 12-06-2010 11:28 AM
"Bounce to disk" problem! OfficialYoungDiz Pro Tools M-Powered (Win) 1 09-28-2009 07:52 AM
Another "weird" MP3 Problem after bounce. Elton Hyland Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 5 11-24-2008 03:13 PM
"bounce to disk" stutter problem calden Digidesign Hardware & Software 2 07-06-2003 03:42 PM
