play flashes then stops. session wont play.
i have recently upgraded from pro tools 8 to PT9 and after finally getting everything sorted I have a problem getting my sessions to play. When i press play the play button flashes once then the stop button flashes and nothing happens. There is no error message or anything. The I/O settings are correct and it is recognising my hard drive in the I/O window fine.
I have tried both old pro tools 8 sessions and new PT9 ones i have created for test purposes and no joy... any ideas? |
Re: play flashes then stops. session wont play.
What interface?
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Did you select Wait for Midi note? Spend a little time with the manual. Open up the big transport window and uncheck the clock symbol?
focusrite saffire pro 24 interface.....
no i haven't selected anything.. the wait for midi note is unselected.
I appreciate that i need to spend time with the manual but surely everything should just play upon opening. The I/O settings are correct, and no eror is popping up |
If that doesn't help, give us specific info on where your tracks are routed and what your IO Setups looks like on the Output tab. |
defaulted the I/O setup and nothing has changed with regards to playback.
All tracks are routed to output 1-2. In the output tab the output 1-2 is routed to out 1 and 2 on my saffire. I am pretty sure it is not a routing issue as it is not just a case of me not hearing anything, but a case of the session just not playing at all. I would post images by the way but am not sure how. It says I may not post attachments under posting rules for some reason. If anyone knows how i change this, it would be very helpful with regards to communicating my problems. cheers |
One way to post images is to upload them to a free photobucket account and link to them in your post.
Do you get playback from other applications with the Saffire?
yes it works fine with everything.
It must be a setting or something within pro tools, im sure. the timebar doesn't move at all. It is not just a case of me not hearing anything. Quote:
Music won't play. Play button flashes and Stop button lights up | Mattitude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 24 | 04-16-2020 03:03 PM |
Session wont play | Featherstone | Pro Tools 10 | 5 | 07-20-2013 12:34 PM |
Pro tools 10.1 I open session tracks wont play says output map is currently inactive | shamanrock | Windows | 16 | 01-23-2013 06:22 PM |
Play button flashes before starting | jonathans9 | Pro Tools TDM Systems (Mac) | 5 | 04-19-2008 02:09 PM |
My session wont play -7401 dae error | MaKoRancid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-28-2004 03:25 PM |
