Old 02-25-2011, 04:16 AM
mackback mackback is offline
Unhappy no sound from mbox, macbook pro
I just bought a new mbox pro (3) with pro tools 8 LE and I can't get any sound from the mbox. At first I had trouble installing pro tools and it couldn't find the hardware, it seems that it got fixed because I can open pro tools and it says that it's connected to the hardware. But I can't get any sound from my mbox except for the metronome in pro tools. When I play music in spotify the music still comes from my macbook, and not the mbox. Please help me, I'm loosing my mind!
Old 02-25-2011, 09:31 AM
HD2 HD2 is offline
Default Re: no sound from mbox, macbook pro
Go to the set up menu and select playback engine. Make sure the mbox is selected in the drop down menu.
Old 02-25-2011, 09:59 AM
jbasil jbasil is offline
You also must boot the Mbox Pro's control panel and set up the unit's routing. The one I have been using did not boot up in any kind of routed state. Had to set it up. Unfortunately, PTools and this control panel do not communicate with each other much, except for the passing of signal and acknowledging how the other is set up. Put the Mbox control panel in the dock. You'll need to access it often.
Old 12-21-2011, 05:28 AM
Hi again!
As of yesterday, my mbox pro 3 isn't giving out any sound anymore. I can see in the software programme (mbox pro) that i have a signal and i can start my ptools 8 le, but no sound is coming out either from the speaker outputs or the headphone outputs. Sometimes the speakerlight is yellow and sometimes it starts to blink with a blue light and sometimes it's green. I need help right away, because i have a final project for one of my collegeclasses, due soon.
Old 01-08-2014, 04:12 AM
bcrichguitar bcrichguitar is offline
Hello guys.
Try this !
Go to AUDIO MIDI SETUP than choose whatever device(Interface) you have .
Right side of AUDIO MIDI SET UP window you will see CLOCK SOURCE . What do you see on Clock Source???? INTERNAL ???? if so , just select different clock source and back to Internal . You will hear the sound from Monitor again !!
Hopefully this helps
Mbox pro and Macbook pro no sound Pehja Pro Tools 9 1 09-28-2013 07:42 AM
Macbook Pro + Mbox 2 mini no sound kidzzz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-27-2010 03:30 PM
macbook pro + mbox 2 mini no sound kidzzz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-23-2010 07:34 PM
Sound dropouts with MBox 2 on MacBook mrchikita 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-05-2007 04:54 PM
New MBox User...MacBook or MacBook Pro? calpilot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-30-2006 12:17 PM
