Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 02-10-2011, 12:24 AM
Top Jimmy's Avatar
Default *WARNING* Waves IDR whacked!!!!!
I have now confirmed this in both V7 and V8 on both Mac and PC. This occurs in the IDR plugin, L1+, L2, L3, and probably any other Waves plugin that offers the IDR dither.
Switching through the dither types can cause random dithering results as seen on a bitscope. If anyone wants to see this, bring up L1+ and put it on 8-bit so that you can see this on any meter. Switch through the types and you'll find type 2 gives random results with noise-shaping on and you'll also see random results when switching to "None"(off).
I tried to report this to Waves and the support tech treated me like an idiot.
See a couple of screen shots:
http://dl.dropbox.com/u/2505899/IDR%20Fault.JPG
http://dl.dropbox.com/u/2505899/IDR%20Fault%202.JPG
Better yet, see it for yourself.
Here's my correspondence with Waves word for word with a little redaction. Start at the bottom.
-------Answer from Waves at 2/8/2011 4:05:17 AM
Hi James;
I am defiantly up to date regarding what is included in the AudioTrack- let me repeat:
Both the IDR and the DLA are only components which are being installed with ANY Waves Plug-In.
However, they are not Plug-Ins, and therefore I do not understand what the issue that you are having is.
The DLA is a component which improves the delay compensation of the host and cannot even be loaded.
The IDR is related to dithering, but again- it works only in the background.
BTW, I know how to open a link...
Have a great day
If you need further assistance feel free to contact us or visit www.Wavesupport.net
Best Regards,
XXXXXXXXXXXX
Waves Technical Support Staff
-------Question/Reply from XXXXXXXXXXXXXXXXXXXX at 2/7/2011 3:27:00 PM
XXXXXX,
Thanks for the reply. It seems that you may not be up to date on what came with Audiotrack. I also got the IDR plugin and DLA installed with it. DLA I cannot use since it is a TDM plugin.
The IDR plugin properly dithers at 20 and 16 bit depths as seen on a bitscope. But, it also sometimes adds noise when switched to "no IDR" The linked pic shows the noise on the bitscope. I checked the link and it is good. Since this form doesn''t support hyperlinking, copying and pasting the link in your browser URL will get you to the picture.
As for Audiotrack, it seems to be working just fine. I bought it because it is one of very few plugins on the market that can actually do upward expansion. The compressor ratio can go below 1.
-------Answer from Waves at 2/6/2011 6:47:07 AM
Dear James,
All of the Waves products include the IDR component.
However, it is not an actual Plug-In and you can't really use it.
Originally, it was a dithering Plug-In.
BTW, the link you sent me to the screenshot didn't work.
Please let me know if something is wrong with the Audio Track Plug-In.
Have a good one,
Best Regards,
XXXXXXXXXXXX
-------Question/Reply from XXXXXXXXXXXXXXXXXXXX at 2/4/2011 2:26:51 PM
I purchased Audiotrack last night from audioMIDI.com. After installing version 8, I found that the IDR plugin was included. I opened IDR and a bit scope to see the dither being added. I found that when switching to "no IDR", there would sometimes be a noise in the 22nd-24th bit level. Sometimes it would be in one channel or the other. Sometimes it would be non-identical in both channels. Here's a link to a pic of the issue.
BTW, if this is the second time you see this bug report from me, when i first submitted it, it appeared as though my account login had expired and there's was absolutely no indication that the form data had been successfully submitted.
IDR is a plugin and you can use it.
_
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.3, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 02-11-2011, 10:27 AM
aka21stCentury aka21stCentury is offline
Default Re: *WARNING* Waves IDR whacked!!!!!
Did Greg Aitken write this? No. Avoid all dithering algorithms unless his name appears as an author.
This cheap deal is just a scam to force users to buy an ilok/use an ilok.
(OT) Laptop users cannot use iLoks w/o hubs & third party chipsets. Soon another nightmare is about to crop up (USB-3 mangled code). It took years for Opcode (who rewrote Apple's USB protocol) and Microsoft (who released buggy USB 1.1 code in their gold master W-2000). They were two years behind Apple (I mean Opcode).
Then AVID releases an mBox Pro 3 at 1394a speeds knowing firewire is like SCSI, the slowest common denominator wins? Designed for Apple's 1394(b) macbooks. Duh? Many do not like to lug around a 17in laptop. They are more likely to be dropped or mishandled (solder balls beneath the chips come loose when case is flexed).
Lightstream is finally coming (optical firewire) please work with the 1394 group here and Intel and get a Pro unit ready (that is stable) for recording off house mixers. 64 channels. How many years now?
It will take years to get the bugs out of USB-3 backwards compatible code and the chipset makers to get 'it' right. Dump iLoks now! IMHO.
(end of OT rant)
Maybe if Dave O. wrote the code (Opcode's founder) I'd think about using it. But unless as above; Greg Aitken or Dave O., forget it. 44.1 or 88.2k... is my solution.
Right on Top Jimmy for scoping this out.
Old 02-11-2011, 11:21 AM
danander11 danander11 is offline
The Man is holding us down..... It's time we revolt... it worked for egypt.
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 02-11-2011, 12:02 PM
sunburst79 sunburst79 is offline
Someone needs to step down! I just dont know who.
Normally people praise Waves support. I find it odd that they would answer in this way.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 02-11-2011, 03:14 PM
Yep.. I know I come off as a Waves fanboi sometimes, but they have always been great for me.. and I can ask some pretty dumb questions
Here I am,
Hobo Shave!
Old 02-12-2011, 01:14 AM
ejwells's Avatar
ejwells ejwells is offline
Tin foil hat anyone?
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
Old 02-12-2011, 10:04 AM
I disagree.
I think its all about getting them to join the WAVE's ecosystem. Like a drug dealer giving out free samples to the potential customer. Once you need to pay WUP for the first time many folks will spring for a bundle.
Ilok is better than lost Challenge and Response auths.
Scott
Core 2 Specs Page
Old 02-12-2011, 10:19 AM
necjamc necjamc is offline
That's only a problem for the LE crowd. Everyone else (M-Powered, 9, and HD) all have iloks. So as far as PT it's only LE 7 or 8 people that will be forced. Buying an iLok and That audiomidi deal is still cheaper than buying Audiotrack at Waves.
Old 02-12-2011, 10:43 AM
DJ Hellfire DJ Hellfire is offline
It's amazing how you could spend so much money and they talk to you this way. I can imagine if I bought a high end Benz and a dealership employee used this type of tone with me, I'd probably punch him in his mouth!
www.HellfireBeats.com
Akai MPC 2000XL, Akai MPC Renaissance, NI Maschine MKI, Mackie 1202VLZ Pro, Akai Advance 61, Focal Alpha 80, UAD 2 Apollo Quad, UAD 2 Satellite Quad, UAD 2 Octo PCIe, Pro Tools 12, Neve R6 "Lunch Box", Neve Portico 511, Neve Portico 551, Neumann TLM49
Mac Pro 4,1 (5,1 upgrade), Early-2009, 3.46GHz Nehalem 12-Core, 32GB RAM - OS 10.12.5
13" MacBook Pro, Late-2011, 2.4GHz Dual Core i5, 16GB RAM - OS 10.12.5
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - OS 10.12.5
Old 02-12-2011, 10:50 AM
Maybe i am missing something, but i can put IDR on an insert as plug for Dither. (Ver 7) Is it not suppose to work that way? Audiotrack is the only waves plug I have.
major Waves TLC warning Mark Dann Pro Tools TDM Systems (Mac) 29 07-06-2009 08:21 PM
Warning: Waves V5 EF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 10-12-2004 09:52 AM
Waves 3.5 and PTLE 5.1 WARNING! citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-18-2002 12:56 AM
WAVES 3.5 warning !!! Dutchmuzik Pro Tools TDM Systems (Mac) 14 06-18-2002 06:45 PM
pro control faders are whacked out John Croarkin ICON & C|24 0 04-16-2002 10:08 AM
