Old 01-17-2011, 02:06 PM
H-Musikk H-Musikk is offline
Default H/W Insert delay
I tried to follow he procedure to see “Setting a Hardware Insert Delay Offset”
In the I/O setup under “H/W Insert delay” shows 0.00 (two decimals) but I’m only able to set the value for e.g. “1.00” or “2.00” etc. I have measured the delay (following the procedure) and want to insert “0.97” but I cannot do that. Am I missing something here or is it not possible to type in the decimals ?
Regards
www.h-musikk.no/english.html
Norway
ASUS X99-E, Intel Core i7-6850K, Noctua NH-U9S, Corsair Vengeance LPX DDR4 2133MHz 16GB, Samsung 960 EVO 250GB M.2 PCIe SSD (System), Samsung 850 EVO 500GB 2.5" SSD (Data), Samsung 850 EVO 1TB 2.5" SSD (Sample), WD Desktop Black 1TB 3.5" (Audio), Gigabyte GeForce GTX 1060, Corsair RM750x 750W, Samsung 34" LED Curved, Windows 10 Pro 64-bit, Lynx AES16e, Aurora 16, Cakewalk by BandLab, Pro Tools 2019
Old 01-17-2011, 03:01 PM
Default Re: H/W Insert delay
I had no trouble doing that. Maybe you need to click before the . to change that field and after the . to change that field
Old 04-11-2011, 01:57 PM
I still havn't found out of this. Anybody else seen this problem?
Regards
Norway
Old 07-09-2011, 07:34 AM
mannnu mannnu is offline
Its the same problem for me! I Cant enter 0.65; it automatically transforms it 0.00
If I try to enter 2.06 protools write 2.00 ...etc
I dont understand what happens; my config is Windows 7 64 bits Protools 9
Did you fix your problem H-Musikk?
Thanks.
Old 07-09-2011, 08:05 AM
Wish I could watch what you are doing. I just checked mine again and I can enter any value I want and it enters fine
Old 07-10-2011, 12:36 AM
ninjafreddan ninjafreddan is offline
Same problem here. It didn't work with 9.01, worked with 9.02, but doesn't work with 9.03.
Cheers
Frederick
Sound On Sound contributor
Ninja Production
PT HD 9.03 + HD Core card, Nuendo 5, Cubase 6, Wavelab 7, Samplitude 11, W7 64bit, ASUS P5B, Core 2 Quad 2.4GHz, 4Gb DDR RAM, UAD-2 QUAD (all plug-ins), RME RayDAT, Lavry DA-10, Mytek Stereo192 ADC, 2xApogee DA16X and Rosetta 800, Quested V3110 three-way speakers, Avantone MixCubes, Euphonix MC MIX, Novation Remote SL61 and Zero SL MkII, lots of funky outboard and analogue synths.
Old 07-10-2011, 02:53 AM
I had the 9.01 version and it doesn't work; so I just instal the 9.03 and it doesn't work to...
You said it works with 9.02 version ; I don't try this version. Is it possible to instal it when the 9.03 is installed?
Old 07-11-2011, 09:13 AM
Angry Re: H/W Insert delay
I just try with the 9.02 version and it doesn't work to!!!!!
How can I do??!!!
Old 07-13-2011, 01:56 AM
I'm on 9.03 now and it works fine here now.
The only thing I know that I have done with my DAW (Win7 64) in the past is that I have change Region and Language setting to English (US) (instead of European/Norwegian). This was because I had to do so when I started to buy Waves plugins. Maybe this affects PT as well?
Regards
Norway
Old 07-16-2011, 08:50 AM
Thanks for your answer Hmuzikk,
Can you describe me precisely what you done in windows seven configuration?
Thanks Manu.
H/W Insert Delay spaceman Tips & Tricks 17 04-02-2013 12:43 AM
PT9.0.6 H/W Insert Delay ADC kafka Windows 2 02-28-2012 07:28 PM
insert delay vin7 Pro Tools 9 1 09-29-2011 06:52 AM
H/w insert delay?? vin7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-08-2010 03:33 PM
Hardware Insert Delay value for 888/24??? cronos Pro Tools TDM Systems (Mac) 3 01-29-2010 06:50 PM
