Avid Pro Audio Community |
hi protools 9 its suppost to be able to do this ... but wen i try to open it just with the ilok ask me to connect the interface....
Are you talking about on a laptop? - for use with on-board sound via ASIO?
"Well, of course, their requests for subsidies was not Paraguayan in and of it is as it were the United States government would never have if the president, our president, had not and as far as I know thats the way it will always be. Is that clear?"- Chevy Chase, Spies Like Us. |
yes a laptop ... just to mix... anywhere
You need to have an ASIO driver installed for a sound device. If you want to use your laptop output, ASIO4ALL is what's recommended. Check out item #1 here: http://duc.avid.com/showthread.php?t=287927
PT 10.3.4 VEP 5.1x 828mk3 Win8 (x64) HP ProBook 4730s PT 10.3.4 DP 8.01 VEP 5.1x 828mk3 ADA8000 MTP-AV Mac Mini 2011 ML.3 |
....as a follow-up question to the OP's: does PT9 still finish loading after the connect interface message?
If so, then one should be able to select any interface after loading is finished, and then everything should be fine shouldn't it? .
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Can I open Pro tools MP 9 without going through the M-Audio interface? | Majik Hat | Pro Tools Software (Mac) | 1 | 04-17-2012 06:37 AM |
| Can I use my PT9 ilok to open PT8? | ren-lex | Pro Tools 9 Discussion | 3 | 02-22-2011 09:39 AM |
| Is there a keyboard interface I can open on ProTools LE 8? (I'm new) | Spooner83 | General Discussion | 3 | 08-13-2009 08:10 AM |
| Can't open Pro Tools 8! Requires iLok? | DJ Hellfire | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 8 | 04-04-2009 05:55 PM |
| Can U open 192k session on 96K interface? | johnnyv | Pro Tools TDM Systems (Mac) | 6 | 02-09-2002 03:17 PM |
