Avid Pro Audio Community |
Every time I try to insert any of the AIR plugins on a track, I get a beachball and pro tools freezes. All other plugins work great. I've repaired permissions, deleted preferences, and performed a clean install of PT9 but still same result. This is without any interfaces connected. I'm running a MacBook Pro 2.4 GHz Core 2 Duo, 4GB Ram, OS 10.6.5. & PT 9.0.1.... any suggestions? |
You are using the "full" installer? and not the upgrade installer! And you are installing Pro Tools for the first time and not installing on top of an old version !!! Maybe try running the 10.6.5 combo updater for SL Should work fine of course! Chris
PT Help Videos... http://www.youtube.com/view_play_lis...EC1AEC94DB22D6 PT MAC Troubleshooting... http://duc.avid.com/showthread.php?t=54888 Producer, Engineer, UKmastering E-Mixing & Mastering facility www.ukmastering.com PT10.3.3 Lion HD6 accel Magma PE6R4 Control 24 Harpertown 8-core UAD-2 Quad / SSL Duende Native. Manley Vari-Mu, Manley Massive Passive, Solid State Logic VHD, Anthony De Mario ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring. |
Hi Chris,
Thank you for the response. This is the first time Pro Tools is being installed on the Mac. I'm using the new full installer of 9.0.1. Everything else works perfectly... Very weird. Thanks, Kevin |
check the permissions of the AIR plugs in the Plug-Ins folder
I haven't seen a problem lately but I use to in OSX 10.2
"Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements |
9.0.1 is an update!! You need to install PT 9 full installer before 9.0.1 Run the uninstaller first then trash prefs and re-boot before running re-installing pt9 full then 9.0.1 Chris
im pretty sure there is a full 9.0.1 installer if you read the release notes it mentions having to do something if you used the update but not having to do it if you just use the 9.0.1 full installer.
On the Avid download page both a 9.0.0 to 9.0.1 updater and a 9.0.1 full installer are available.
Just an educated guess, but I imagine the updater would not run if 9.0.0 is not installed.
Just rockin'...what more is there? Bill in Pittsburgh |
hey there,
having the exact same problem. Did the fresh install, etc. What ended up being the solution to this problem for you? thanks, Matt Quote:
Bump. Anyone manage to chase this down?
Try this post: http://duc.avid.com/showpost.php?p=1810484&postcount=64
Aaron Mulqueen |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Pro Tools Plugins Plugins Plugins | psmworld | Buy & Sell | 0 | 01-31-2013 09:33 AM |
| UAD Plugins and Pro Tools | Dot | Pro Tools 10 Discussion | 13 | 08-21-2012 04:50 PM |
| Plugins for Pro Tools LE vs Pro Tools HD question? | zilby | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 3 | 03-31-2005 07:05 AM |
